Cleaning around Lugnuts
Discussion in 'Dodge Challenger Cleaning and Detailing Forum' started by SRT-Tom, Mar 18, 2012.
    I found a fast and easy way to clean the grime around recessed lug nuts. Simply use one end of a Q-tip dipped in Windex (or some other cleaning solution) to lossen the dirt around the lug nut and use the other end to dry it. Works great.
    This same idea is also good to clean the small recessed parts of the Brembo brake calipers.
  2. genotex
    genotex Full Access Member
    WIzzzzzconsin
    Qtips are readily available in the garage at all times! Part of the 'toolkit' :)
    Works great cleaning around/edges of any lettering as well as door handle/gastank/anywhere crevices are ...
    (especially wax removal/polishing)
  3. heminit
    heminit Full Access Member
    Central Arkansas
    Thanx for the tip!
  4. genotex
    WIzzzzzconsin
    He made a FUNNY !!! :chewie::chewie::chewie:
  5. Storm Rider
    From cleaning ears to cleaning cars Q-Tips do it all.
