Oil Filter Comparison
Discussion in 'Dodge Challenger General Maintenance' started by SRT-Tom, Dec 26, 2018.
    This is an interesting oil filter comparison in which 5 filters are cut open to reveal their internal construction. Here is the order of preference:
    1. NAPA Gold
    2. Wix
    3. Bosche and Purolator
    4. Fram
  2. ZEN357
    I used to run K&N until I saw a K&N and a Mopar cut open. The Mopar was way better in the comparison video.
    been running K&N in mine since I bought it in 2011. no problems at all.
    Here are three short videos by Pat Goss (Motor Week) explaining how you can incur costly engine damage if you use cheap and inferior oil filters.
    B5blueRT likes this.
  5. Hopslayer
    I put a K&N in the first time I changed the oil. Might use an Amsoil one next time, as I can get Amsoil cheaper than Royal Purple.
  6. 2009 Classic B5
    Aurora, CO
    It would be interesting to hear what Fram has to say about their product, but I bet nothing ever happens. Fram should meet minimum OEM requirements but that is only the minimum. If you change oil frequently there should be essentially nothing to filter out. Wear debris should be minimal if non-existent until near failure time. So I still recommend changing oil frequently to avoid the problems of filtration altogether. But I will change my filter selection to Napa or Wix because of this article. I don't believe there will be any advantage to filters marketed by oil companies as they will have filters made for them. Much like NAPA/Wix and Purolator/Bosch. Same filter, different brand name.
  7. IG0R
    IG0R Member
    BALL GROUND GEORGIA
    FRAM used to be the best in the 60's and 70's but failed to upgrade their product to modern specs and performance.
  8. Wizard of Iz
    Good comparison by Luke at Steve White Motors on the Fram vs the Mopar vs the SRT oil filters.
  9. 2017 Redline HC
    Good info, thanks. I changed to the SRT filter last fall.
  10. Wizard of Iz
    Good info indeed.
    I've been using the SRT filter in my 2015 SRT 392 since I bought the car in late 2017. It's my favorite thing to get for "free" with my Amazon Prime points.
    I'm not sure one will fit in the tight filter housing area in our 2017 Durango R/T so I use the appropriate Mopar filter..
