New Member
Discussion in 'New Member Check-In' started by Chuck P, Dec 6, 2021.
  1. Chuck P
    Chuck P New Member
    New owner of a 2015 Challenger R/T Plus. Wondering if anyone knows the minimum size (hopefully 215 or 225) and the maximum size (hoping 255) tires that fit on the 20"×8" rims. Have 245/45zr/20 on all four wheels now. Thanks, Chuck
    After re-reading your post it sounds like you want to STAGGER front and rear tire heights. :boxed:
    I would NOT Recommend that drastic of a height difference.
    My 2010 SRT came from the factory with 245/45/20 and 255/45/20
    And I replaced them with 275/40/20's all the way around.
    Wanted to go old school Skinny-FAT, but the forged SRT rims are 9"
    Welcome to challengerforum.com
    A 245/45-20 is the widest tire that will fit on an 8-inch wheel. A 225/40-20 is the narrowest tire that will fit on an 8-inch wheel. The problem, however, is that a 245/45-20 aspect ratio tire has a 28.7-inch diameter and a 225/40-20 has a smaller 27.1-inch diameter. This will throw your speedometer off.
    Either buy wider wheels (e.g., 9 or 10-inch) with the proper offset, or keep the 245/45-20s that you have.
    https://www.tyresizecalculator.com/charts/tire-width-for-a-wheel-rim-size-chart
    oldgeezer likes this.
  5. Wizard of Iz
    Welcome to the neighborhood.
    I hope you're enjoying your new-to-you Challenger.
  6. B5blueRT
    Welcome, glad you decided to join the forum. In case you're not sure, your 2015 RT PLUS came from the factory with 20' x 8.0" wheels. (I confirmed with my build sheet.)
  7. Chuck P
    Chuck P New Member
    Thanks for all the replies.. wanted wider rear tires, narrower fronts, sorta old school... love the 8" rims so I will keep researching to find narrower, taller fronts etc.
  8. SRT-Tom
    Don't go below a 225 with your 8-inch rims. That size tire will not wear or perform properly. Look at the following diagram (image on the right).
  9. Chuck P
    Chuck P New Member
    Thanks
  10. gostro
    gostro Full Access Member
    Indiana, US
    Welcome! Thankfully, everybody else already answered your tire questions because I'm not all that great at it yet!
