Wondering about cost of maintenance?
Discussion in 'Dodge Challenger General Maintenance' started by Duck Johnson, Jan 18, 2022.
  1. NC20RT
    It's still probably a decent deal, especially if they include some other fluid changes. Did you find out what other things you get besides the tire rotation? if nothing else, it's up to you. No great bargain, plus you are stuck with them. I probably would pass at $300. Also what if you sell your car before the oil changes are used up?? Things happen.
  2. stingray
    Does this package specify what kind of oil they use? Conventional or synthetic?
  3. Duck Johnson
    Duck Johnson Full Access Member
    Justin
    Yes, synthetic
  4. stingray
    How many quarts on that v6 Penstar?
    The 3.6 takes 6 quarts of oil.
  6. stingray
    I t hink the 392 takes 7 quarts.
  7. stingray
    Anyone have pics of bottom splash pan to protect engine from water on Challenger R/T 392 SPWB? (probably same on all Challenger models). This part needs to be removed in order to do an oil change.
  8. SRT-Tom
    That's correct. Same for the 6.1 and 5.7 engines.
    stingray likes this.
