Tail light Bulb Replacement
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Mar 15, 2022.
    Here are the steps to replace a tail light bulb on a Challenger:
    (Part #3057)
    Remove the large wing nut from the side interior trunk panel behind the taillight.
    Pull back the panel, remove the large wingnut behind the panel.
    At the top of the taillight, the trim piece has 2 tabs that have to be moved up.
    Now pull the taillight straight out.
    You can disconnect the plug if you want, push/slide the red retaining tab and then wiggle the plug off.
    Turn the bulb plug counter-clockwise until it pops loose.
    The bulb pulls straight out. Replace.
    Reverse process to reinstall.
    Been There, Done THIS :)
    Same on mine also.
    Green with Envy likes this.
  5. IntimidatorRT
    Got mine from webelectric.
  6. Wm TPA SXT
    Wm TPA SXT Full Access Member
    Will do that to mine after I get the New Wheels and Tires on :)
    IntimidatorRT likes this.
  8. stingray
    Is it the same replacement process on the 2022's?
  9. Wm TPA SXT
    The Sequential kit is for earlier Challengers
  10. 70-426_10-SRT
    Technically, THIS is the "earlier" Challengers
    I wanted but never did add the extra to my early '70 Challenger
    but never did
    NC20RT and Wm TPA SXT like this.
