Any reviews about Diablotoona?
Discussion in 'Dodge Challenger General Discussions' started by Civitas7377, Mar 19, 2022.
  1. Civitas7377
    MN
    Considering them for a follow up Tune to address a "Too Lean" error.
    SSi Performance isn't returning my calls.
    Do you mean DiabloSport? A better and safer option is to use HP tuner. It is not a handheld, like Diablo, but software that tuners use- each tune is custom.
    Civitas7377 likes this.
  3. Cloverdale
    If you're certain there's been no after market tuning adjustments made then you can proceed with anyone's product. HP Tuners is more versatile (can read a Diablosport and other's tunes) but more expensive.
  4. Cloverdale
    You would want to diagnose and remedy the AFR issue 'too lean error' before playing with the tune.
  5. Civitas7377
    MN
    The 'too lean error' was due to the first custom tune. (Factory was fine.) Shawn sent me a 2nd tune to fix it. Didn't work. Then when ghosted me. So we're trying someone else.
  6. Cloverdale
    With the HP Tuner you can save a copy of a previous or factory tune and change it back in situations like this. You must be using a device already if your applying different tunes (assuming your not sending the entire ECM)?
  7. Hellbee
    Hellbee New Member
    Bremerton Washington
  8. Hellbee
    Hellbee New Member
    I have a Diablo In tune i 2 and love it ! Ive had it for 5 years and numerous tunes.
