Adding a Turbo
Discussion in 'Challenger R/T Engine & Performance Modifications' started by SRT-Tom, Oct 10, 2022.
    Here is an interesting video showing the proper way to add a turbo to a 5.7 engine.
  2. stingray
    :badidea: heat,wear to engine failure is the enemy of all engines including the 5.7. The 6.4:shitsweak: internals aren't strong enough for this.:uhoh2:
  3. Cloverdale
    That's some interesting info. If I still own mine when it's time for rebuilding a couple small changes will allow me to safely turn up my supercharger boost (Magnuson currently at 6 lbs which safely takes the 5.7 to 550 crank hp with headers, Corsa and intercooler). It's also common for twin turbo BMW owners to go to a single turbo for increased performance.
    Moparisto likes this.
  4. Moparisto
    As Richard Holdener on Youtube is fond of saying: more boost needs more ring gap.
    Also, though the much-vaunted, all-conquering gem known as the 5.7L Drag Pak engine with its 3.0L Best Generation So far Whipple blower that screams to 10,000 RPM and posts 1600hp is a 5.7L, of course, it is most resoundingly NOT made of the same stuff as the street 5.7L.
  5. stingray
    :facepalm::snoopfacepalm:
  6. Moparisto
    But, but why NOT put a turbo on it and just see how much power you can get and for how long? I mean, it may be egg-timer-duration, but, hey, the FUN!
  7. stingray
    So you can see how fast you blow up the engine?
  8. Moparisto
    No, to see how much power you can make before you convert the engine to a cloud of shrapnel!
    :D
    stingray likes this.
  9. Moparisto
    Same with Supra owners. I think the overall efficiency of a single larger snail is what gets them most interested. Once a turbo is singing, big single or dual small ones don't seem to make much difference, per Richard Holdener.
    Only 326 bucks. That is some cheap horsepower there.
  10. stingray
    $326 to blow your engine up.:facepalm::snoopfacepalm:
