speed sensor messed up?
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by Dave McCargar, Aug 2, 2023.
  1. Dave McCargar
    Dave McCargar New Member
    Michigan
    I purchased a 2018 RT at an auction. Nice car. 30k miles. It had after market wheels with locking nuts and no key. Long story short, while replacing a wheel stud I had to drill out to get the last wheel off I had to remove the left rear wheel bearing. After putting it all back together I have an ABS light and no traction control, also cruise control not working. Thoughts on what I screwed up?
  2. Niles
    Niles Full Access Member
    Huntsville, AL
    A failed ABS sensor at one of the wheels will cause that. Maybe it came loose or the wire is broken.
