2017 challenger 3.6 headlights not working
Discussion in 'Dodge Challenger General Maintenance' started by musky, Sep 9, 2023.
  1. musky
    musky Member
    canada
    i got a 2017 challenger 3.6 l My high and low beams are out. The day time lights work which i assume are the rings around the headlites but the headlights do not come on at nite any ideas on this?
    The problem may be a blown fuse or a bad ground.
    musky likes this.
  3. musky
    musky Member
    canada
    do you have a diaagram on the fuse location for the 3.6 for the headlites because some say its in the trunk others say its under the hood.
    musky likes this.
  5. musky
    musky Member
    canada
    ya i dont have those 2 yellow fuses in my fuse box like the pic has..
    You're correct. The fuse locations in the diagram are for cars with HID headlights. Your Challenger, apparently, does not have them. Sorry I can't help you further.
    musky likes this.
  7. HellKitten
    Being a fairly new car I can't imagine it would not be much more than a fuse or relay. Now that said if you bought the vehicle used and it was in a accident, maybe something is not plugged in fully. Your owners manual will give the location of the fuses, if you don't have a manual, you can download it.
    musky and Niles like this.
  8. musky
    musky Member
    canada
    would 1 blown headlite bulb make the other dead too, im asuming not? Also anyone know where the relay switch is.
    The headlight relay is located in the fuse box on the passenger side of the engine bay. Watch this video. Start at the 1:28 min. mark.
  10. musky
    musky Member
    canada
    i dont have those 2 relays either. i checked the bulbs they look like halogen.
