fog lights...
Discussion in 'Dodge Challenger General Discussions' started by LEGENDARY70, Feb 28, 2024.
  1. LEGENDARY70
    TEXAS!
    Hello all.
    Am I able to switch out the fog light bulbs for led bluish or white color bulbs just like on headlights?
    Best.
    You can replace the fog light bulbs with LEDs. However, you will also need an anti-flicker module. Watch this DIY video. Diode Dynamics has a complete plug and play set-up for $105.
    I would recommend buying a pop riveter gun and plastic rivets from Harbor Freight. Do not go to the dealer because they will rip you off.
    Buy LED Light Bulb Replacements for Your Vehicle (diodedynamics.com)
    Chuckv and LEGENDARY70 like this.
  3. LEGENDARY70
    TEXAS!
    I apologize. Just to be clear. Not blue color bulbs. I switched out my headlight bulbs with these.
    https://www.amazon.com/gp/product/B0CMWTQ8N2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    But now my headlights look amazing and my fog lights look yellowish and dull lol.
    According to the vid the size is h11. Other sites state it is an h10?
    i found these.
    https://www.amazon.com/AUXITO-Light-Lumens-Brightness-Replacement/dp/B09BCNDL74/ref=sr_1_6?crid=23YOVCL5TITS5&dib=eyJ2IjoiMSJ9.9cj7ApVfKzS2UVcfU_bm08TToAJgy0G7-NzovqaNiMcKtHQ5UkeEYpy09BGaXG12LOuZ254WlaH_jGoNfbrBOOxgJUxxdXHu_eYzlv9UE__I-YN4uXIYzG9-oxP1hxaYBK8iD5PxI7HSNZq1X3uRWwGtQxcdB5FhtmI23xvX64i9S5CwZGTXMa-kVB8kmCgAAuCtMOc3c1GeviTiY5RDaz_xP8D6wM0Fskbxb4Mu2htmumKkevb2kOJQAnU-T_Q5zPRoGXcVPzjpvqHPTZkWnv2QVg4P2T1YLKGswbET40g.T_-BqbMeNwoNrGwWp7n4QtmL2-aHIBrmpA_sH63jflI&dib_tag=se&keywords=2010+challenger+led+fog+lights+bulb+h11&qid=1709393755&sprefix=2010+challenger+led+fog+lights+bulb+h11,aps,142&sr=8-6
    https://www.amazon.com/AUXITO-6000LM-Brightness-Lights-Replacement/dp/B09KGSHFWW/ref=sr_1_12?crid=1WBKEGCUITKPP&dib=eyJ2IjoiMSJ9.ek20A8fVVyVUm2y-5e8Ow1vcefN6DCZTaNFtxLx4t2kVUuUBTVUtHgOmckF4skwZGctZmVTDuz6n2P-U3J9cnRf8YJAFMGcDvXF5uZ73NmX8fLwtxyyB_NsLgwOU8hDMxOsmJV0hmoulmcdYWXGcC_dYVxxYzUvKPxS8gevLU1o6Lq4KLTa6Nxi5J17R5lwAyxqbvR_k2o9BPX51_Er4nrn7biejxgSE49sTVlx4OEIikE4BSklWl_EiDhMoq9BK0B_4qgvJfN_RhHpNoR0cRC0SLmhPU65sSCh2OmwoxYw.2Q1laNxIV-ywn7eCgLkG5FCUilSYouVpMMTNKdVT4g8&dib_tag=se&keywords=2010+challenger+led+fog+lights+bulb&qid=1709392633&replacementKeywords=led+fog+lights+bulb&sprefix=2010+challenger+led+fog+lights+bulb,aps,113&sr=8-12&vehicle=2010-40-286------------&vehicleName=2010+Dodge+Challenger&th=1
    thx
  4. Frederick Grayson
    Frederick Grayson Member
    Plantation, FL
    Not all LED bulbs in all cars will flicker and require anti-flicker modules.
    I put AUXITO H11/H8/H16 LED Fog Light Bulbs - the first one you linked - in my 2020 RT Challenger. They don't flicker. I seem to remember I had to swap out the rubber gaskets with either the second set included with the bulbs or the ones that were on the OEM bulbs.
    You should verify that whatever bulbs you buy will fit your car by year.
    LEGENDARY70 and Chuckv like this.
  6. stingray
    :facepalm:
  7. Moparisto
    Are you accusing him of being a flicker?
  8. Nawalins
    Nawalins Member
    I have a 2014 Challenger R/T.
    I watched the video on how to change the fog lights. However, mine aren't L shaped where the harness plug attaches to it. On mine, you can't twist the base to remove it from the housing.
    I don't want to damage anything in the process of attempting to change out the fog lights.
    There's not a lot of space to access the base of the fog lights and I was wondering if there is a preferred method of removal.
    Also, I would like a recommendation for a replacement, preferably an LED instead of halogen.
    Thanks!
    To remove your fog light bulb, turn your wheel in, pry out 4 or 5 push-in fasteners at the front, then pry the wheel well inner back. Take a peek with your flashlight and look for the wire bundle and housing. There are four reusable plastic snap lock fasteners per side of the housing. The bottom one is slightly different. (Note- They are a PITA to unlock from the light housing. Probably 5 minutes per side).
    Diode Dynamics makes LED bulbs for fog lights.
  10. Moparisto
    Fog lights, when used properly (without the headlghts) can be a real life saver in heavy fog.
