Tailights...
Discussion in 'Dodge Challenger General Discussions' started by LEGENDARY70, Feb 12, 2024.
  1. LEGENDARY70
    TEXAS!
  2. fritzthecat
    Yeah, the LED ones draw much less current than conventional bulbs. This affects the flasher mechanism used in many cars. Not sure how to fix it. I have the same problem with my motorcycle, a 1983 Honda. The LED bulbs are nice and bright, but they flash fast. I just live with it.
    LEGENDARY70 likes this.
    i have the same problem with my RAM. i put in the switch back turn signal LED lights in for turn signals, front and rear lights blink normally, but the turn signals in my mirrors hyper-flash. I even got a tazor module to help fix that but no help from it, so i just live with it
  4. SomewhereinTexas
    SomewhereinTexas Member
    Rio Grande Valley TX
    The packaging clearly states "may cause hyper flash and to use a load resister".
  5. stingray
    What does hyper-flash look like?o_O
  6. Moparisto
    I call it "ricer flash."
    The advent of the aftermarket LED bulbs on riced-out Hondas was the origin of this particular problem.
    Not enough current being drawn so the car's electronic brain thinks there are not enough bulbs installed.
    To see a potatoed-out Lada in all its glory, check out this video:
  7. stingray
    :facepalm::snoopfacepalm:
