Uconnect problem
Discussion in 'Challenger DIY/Tech Info' started by Clazar, Mar 14, 2024.
  1. Clazar
    Clazar Active Member
    Pittsburgh
    Thank You again for the video. It makes sense that might work. But I not sure if I pulled the correct fuse. Cause it didn't work. I pulled the fuse that said "center stack" from the rear power box. Nothing I seen says uconnect for a fuse. Does anyone know which fuse controls Uconnect.
    I believe you have to pull the fuse for the radio (F37) that is located in the trunk fuse box.
    If that doesn't work, you can try calling UConnect directly at 866-422-8182.
    2021 Dodge Challenger fuse box diagram - StartMyCar
    Clazar likes this.
  3. Clazar
    Pittsburgh
    Thank you. I'll try that today.
  4. Clazar
    Pittsburgh
    Pulled fuse 37 today. No luck.it didn't work. I will call Uconnect tomorrow. I'll let you know if anything works after I talk to them. But,Thanks everyone for your help.
  5. SFCR
    SFCR Full Access Member
    North Carolina
    Uconnect problems? Uh oh!
  6. Clazar
    Pittsburgh
    I called Uconnect today. I explained what the problem was. They told me that a systenm update was needed. I made an appointment with my local dealer for next monday. I hope it works. I'll let everyone know if it does or doesn't.
    Glad to hear that you may have found a solution.
  8. Clazar
    Pittsburgh
    Thanks for all your help
  9. Moparisto
    But, my screen has always lit up, regardless of status of radio.
    Clazar and HellKitten like this.
  10. Niles
    Niles Full Access Member
    Huntsville, AL
    Do you have any other failed electronic units such as the power outlet? I'm thinking a constant power fuse may be out and it might be labelled for a different electrical component (PDC or ASD perhaps?). Looking at an online fuse diagram, it appears there may be two fuses for it - 37 and 38 (radio and Media Hub/ Console APO, respectively).
    Clazar likes this.
