How to Remove Front End
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Oct 10, 2012.
    1.Raise and support the vehicle.
    2.Remove the left and right front splash shields as necessary.
    3.Remove the belly pan.
    4.Remove the mounting fasteners that secures the front fascia assembly (9) to the inside of the front fender.
    5.Partially lower the vehicle and remove the push-pin retainers (10) that secure the front fascia assembly to the upper radiator support.
    6.Disconnect the Tire Pressure Monitoring System connector.
    7.Carefully pull the left and front side of the fascia out of the fender mounted fascia mounting brackets.
    8.Carefully pull the front fascia assembly forward to disengage the push-pin retainer from the slot in each side of the fascia and disconnect the fog lamp wire harness connectors, if equipped.
  2. Storm Rider
    That sounds like something for the body shop. But 8 steps ain't bad if you are bold enough to try it.
