Problem with blindspot assistant - B285F-15
Discussion in 'Dodge Challenger General Discussions' started by AndreevSXT, Apr 25, 2024.
  1. AndreevSXT
    AndreevSXT New Member
    Bulgaria
    Hello!
    I have a 2015 challenger and I have a blind spot.
    When I start the car, only the left mirror lights up and it says blind spot temporary unavaliable.
    The right glass warning triangle does not light up at all.
    Diagnostics revealed these errors from the photo. Could you please help me, thanks in advance!
  2. Niles
    Niles Full Access Member
    Huntsville, AL
    Welcome. Please post some pictures of your car. We like pictures.
    I'm not familiar with the 2015 model, but I would start with fuses. Search to see if there is a fuse associated with the door module. If you can find door module, does the electrical connection appear to be good with no bad wires? You may need to get a new door module and it may require programming to work in your car.
