Class action re differential failure.
Discussion in 'Challenger News, Articles and Media Reviews' started by Cloverdale, Aug 21, 2024.
  1. Cloverdale
    Came across this while researching whether diff movement is thought to be involved in a diff failure and whether a brace might be beneficial. Anyone personally impacted? Lawsuit includes all V8 powered 2015 and up including R/T. Braces are available for pre and post 2015 Challenger/Charger and a easy install.
    https://www.classaction.org/dodge-challenger-charger-rear-differential-lawsuits
    Sexy Blue likes this.
  2. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    Good to know, I am glad I have no symptoms, yet...
  3. gostro
    gostro Full Access Member
    Indiana, US
    Well, I've got almost 22k on my 21 challenger 1320. No issues. And I do drag race it throughout the year. That being said, after 2 years of racing it, I decided I better get a diff brace put on, since that's obviously a lot of twisting motion and stress on things. I bought a diff brace and the optional race brace from per4mance development.
    Cloverdale likes this.
  4. Dodgehemi61
    Dodgehemi61 Full Access Member
    Michigan
    I would also consider installing the aftermarket driveshaft mid bearing support before you have to replace the completed bearing assembly.
    The nice thing about this one is you do not have to remove the driveshaft to install it.
    JXB Performance Driveshaft Center Support Bearing Upgrade | website (getper4mance.com)
    Cloverdale and gostro like this.
  5. gostro
    Indiana, US
    Thanks, I'll look into that!
  6. Cloverdale
    On my 2010 there's just one front diff mount and when making the swap to LSD (the auto trans Challengers at that point were equipped with the open / non LSD) it requires a much longer bolt and it's a pain to tighten cause it's received by a rotating piece that's difficult to keep from spinning. It may be the same front diff bolt your Challenger has 2 of. Do you know whether they too get tightened into a rotating host?
  7. gostro
    Indiana, US
    I'm not sure, to be honest. I had a shop put it on for me, since I don't have a lift and I had it in for some exhaust work anyway.
  8. Cloverdale
    The diff I swapped in was from my same year (manual trans with the 3.91) fortunately as perhaps using a diff with 2 front mounts might've been problematic or not possible.
    gostro likes this.
  9. Cloverdale
