The 5.7 HEMI with an automatic always required a 5-20W oil for the MDS to operate properly. The newer lighter viscosity spec, of 0-20W reduces internal viscous drag and allows for quick, seamless valve timing changes and MDS hydraulic actuator switching. A 0W-20 oil and a 5W-20 oils has the same viscosity when the oil reaches the operating temperature. Here's a good article, though rather technical, regarding viscosity. What you'll find is that the real difference between an 0W and a 5W is in two areas- Low Temp Cranking Viscosity and Low Temp Pumping Viscosity. See the first table. Putting the Simple Back into Viscosity - Bob is the Oil Guy
The FE difference is in the 0.5% range and probably can only be measured by exacting laboratory engine tests. The cranking and pumping difference is 5°C (9°F) so is small. That is also measured at -30 and -35°C, so essentially very few people will ever start their cars at those temperatures. And if you do live in climates that get that cold, you already know about the difference. The rest of us couldn't be bothered.
How about -20W 150? Good for everything from Antarctic winters to Arabian summers, for engine, transmission, door hinges, etc! Reminds me of the braying imbeciles on a Dodge Neon forum I used to be on. Amsoil specified 5W50 for the manual transmission. (it was actually red auto trans lube) and they pulled out of each other's mouths long enough to laugh me to scorn for DARING to use 5W50 for a transmission. When you know someone whose first reaction to most things is scorn and ridicule, having never done any background research whatsoever, you may be better of un-knowing them. "We ain't never done it that way before" is the calling card of the idiot. Of course, the oil from Amsoil worked very well. On a similar note, merely replacing my gf's transmission oil in her Honda with new Valvoline synthetic, notchiness in shifter feel disappeared.
