Tire plugs.
Discussion in 'Challenger News, Articles and Media Reviews' started by Cloverdale, Feb 18, 2025.
  1. Cloverdale
    I know there are newer tire plug options than the 'string plugs' I continue to use as I've had great success with them. Are they made longer than they need to be (about 7 inches)? More often than not I cut one in half, add glue and plug away.
    HellKitten likes this.
    I carry the old-fashioned plugs for my Challenger. However, the best way to plug a tire is to dismount it and patch it from the inside.
    HellKitten and Sexy Blue like this.
  3. Sexy Blue
    Sexy Blue AKA Bob
    Hudson Valley, NY
    I used them in my van, the string plugs don't hold up to 85 PSI, and 8200# at the scale.
  4. baccaruda
    Now you are making sense , but there is a time in place to use them, if you have a very small pin hole a radial patch is fine with seal cote over either patch . the whole idea is to not make the hole bigger than it was.
  5. Cloverdale
    I've yet to have a string plug fail over many years but never used one on a tire that required more than 40 lbs of pressure. Currently locally it's at least $30 to re and re the tire not including the cost of the repair.
  6. baccaruda
    At my shop a plug patch repair will cost $45.00 to repair and re-balance the tire. the only plug used in my shop is on a lawn mower tire. and by the way any tire repair done voids the tire company's warranty on the tire also. and the tire shop is supposed to buff the speed rating off of the side wall too, but not many shops does that. (V) (H) rated and so on.
  7. baccaruda
    i have repaired tires that were plugged with a patch on the inside for many years too.
    Sexy Blue likes this.
  8. Cloverdale
    Are run flats more difficult to re and re? Are low profile more difficult? Are all run flats low profile? I had a tire shop break the bead on a low profile run flat during removal and I attributed it to their older equipment.
  9. baccaruda
    they can be a little ruff to dismount and mount and yes the tire equipment can be a big factor along with the operator.
    Cloverdale likes this.
