Challenger vs. Charger Dimensions
Discussion in 'Dodge Challenger General Discussions' started by SRT-Tom, Mar 13, 2025.
  1. Don Leblanc
    Don Leblanc Active Member
    Hamilton ON
    Interesting car this new Charger, I'll have to wait to see one in person before I decide if I like it or not. Looking up the specs on it, Yep it sure has some weight to it = 5767 lbs.
  2. William Howes
    William Howes Member
    Fergus, Ont
  3. William Howes
    Fergus, Ont
    I think there are very few cars out there that look as good as a 23 Charger optioned out correctly. That said, I love my 16 SRT Challenger.
    Do you really think that a 2023 four-door Charger looks that good?
  5. Green with Envy
    Marshall Texas
    Just for clarification on the wt of the new Charger, is this wt referring to the EV ? I would assume it would be heavy with the large battery. How much does the ICE engine Hurricane inclined six Charger weight
    The 5,767 lb. weight refers to the EV model. I haven't seen a figure for the Charger with the Hurricane engine. We should see something official in a couple of months.
    That being said, here is my rough estimation. I think the Charger will weigh 4,852 lbs. (a 915 lb. savings over the EV). This is how I calculated the weight:
    5,767 lbs. (EV) less 1,356 lbs. batteries= 4,411 lbs. (without batteries)
    4,411 lbs. + 441 lbs. (Hurricane Six Pack engine)= 4,852 lbs. (ICE Charger).
    Note- I assumed that the weight of the EV's electric motors would be a trade-off with the Six Pack's drivetrain and transmission).
    If you plug in these numbers to the 1/4 ET calculator, you will get 12.42 sec. @115 mph. for the Six Pack.
    1/4 Mile ET Calculator
  7. Cloverdale
  8. baccaruda
    rarest cuda on earth.................................
  9. baccaruda
    lots of mopars ...
    Sexy Blue likes this.
  10. SRT-Tom
    In an attempt to spur Charger sales, Dodge will be releasing a new high-impact blue color called Bludicrous. It joins seven other exterior colors- After Dark, Destroyer Grey, Diamond Black, Peel Out, Redeye, Triple Nickel and White Knuckle.
