Rim scratched...
Discussion in 'Dodge Challenger General Discussions' started by LEGENDARY70, Sep 23, 2025.
  1. LEGENDARY70
    TEXAS!
    Hello all.
    My wife ran over a curb and scratched the rim. Not to bad but it's scratched. Short of taking it to a body shop where they will charge an arm and a leg. do I just sand it and paint it?
    if so, what type of sanding paper and what type of paint?
    They are after market hellcat rims.
    Thanks.
    Green with Envy likes this.
  2. baccaruda
    hi there, could you post a picture please?
    LEGENDARY70 likes this.
    The repair process is sanding, probably starting with something like 600-800 grit and move up gradually to 3000+ grit, then a two/three step polish. You can mask and clear it or straight coat it at that point.
    I wouldn’t recommend tackling this yourself unless you have some understanding and experience how to sand and polish paint. A wheel repair company usually can do this type of repair on site for about $200.
    However, if you are set on doing it yourself, this link may also help.
    How to Fix Alloy Rim Scratches (with Pictures) - wikiHow
    Green with Envy and LEGENDARY70 like this.
  4. baccaruda
    i have not seen this damaged wheel yet have you tom? i have repaired countless wheels in my shop since i sell tires and wheels?
    No, I haven't seen it. I was just providing some information on how to deal with a scratched wheel. As I told him, a professional rim repair shop is advisable.
  6. baccaruda
    without seeing it it could be a simple repair and we do this, to save the member money i have access to a company that specializes all rims and you are looking @ 25% - 50% from what a wheel new would cost, and they balance the wheel when finished and check for trueness also . A picture would help.
    Beep!
    Beep!
    SRT-Tom likes this.
  7. Cloverdale
    If you clean it up yourself consider a spray clear coat as well.
  8. LEGENDARY70
    TEXAS!
    My apologies. I have been so busy with work and school. I will take a picture today and post it.
    Short of a body shop or me sanding it. It's minor but annoying lol. What if i just paint over it? What sort of paint shoul i use? thx
    You can match up your wheel color here and buy a bottle of touch-up paint.
    OEM & Custom Wheel Paint Colors | Touch Up Zone
  10. Dodgehemi61
    Dodgehemi61 Full Access Member
    Michigan
    After you remove the scratches, use good quality primer and color base coat.
    Then get a can of clear 2K clear spray paint.
    It is as close to a body shop finish because it has hardener/activator in it. You punch the bottom valve in the can to add the hardener.
