Charger Hustle Stuff Drag Pak
Discussion in 'Track Talk' started by SRT-Tom, Nov 1, 2025.
    The SRT engineers are back in business!
    Dodge will be producing the Charger Hustle Stuff Drag Pak. There are only going to be 50 of them and each will have a special plaque on billet cover of the 3.0L Whipple supercharger indicating its production number. (Note- Race car only- no VIN).
    While it is impressive that Dodge is producing a new car that is faster than a Demon 1320, with sub-eight second performance, the price will be very steep at an MSRP of $234,995.
    (Note- You can buy this crate engine for $70K).
    The Charger Hustle Stuff Drag Pak is the first race car to be included under the umbrella of the newly reestablished Street and Racing Technology (SRT) Performance division, responsible for SRT high-performance models, Direct Connection performance parts and American brand motorsports initiatives, including Dodge competition in NHRA and the Ram brand’s recently announced plans to return to the NASCAR Truck Series in 2026.
    Key features and upgrades of the new Charger Drag Pak include:
    Engine
    • Whipple 3.0L twin-screw supercharger
    • Newly designed cast aluminum 345 GEN III HEMI engine block includes select six-bolt main metal caps for added strength
    • All-new race forged-steel eight-counterweight crankshaft
    • All-new high-performance forged H-beam connecting rods
    • New high-performance, lightweight billet belt tensioner
    • Diamond aluminum pistons
    • Mopar spec camshaft with 0.675-inch lift
    • Jesel solid roller lifters and rocker arms
    • Billet aluminum, 109mm throttle body
    • Stainless-steel long-tube headers
    • Holley EFI lightweight Dominator ECU
    • Racepak Smartwire power module, 6.86-inch display, V300SD data logger
    • Wet sump oil pump, fabricated aluminum pan, C&R lightweight radiator and cooling fan, electric water pump
    Transmission
    • Coan Racing XLT three-speed automatic transmission with internal accumulator and lightweight 300M internals
    • Coan Racing 9.65-inch (245mm), high-performance, bolt-together torque converter
    • CNC machined billet aluminum stator and billet aluminum cover
    • Cast deep aluminum pan, Reid SFI case and GEN III HEMI bellhousing
    • M&M aluminum three-speed safe neutral shifter
    Suspension
    • All-new rear suspension geometry for improved performance
    • Four-link adjustable rear suspension with diagonal link
    • Custom Drag Pak double-adjustable coil over shocks
    • Adjustable anti-roll bar with spherical ends and adjustable ride height rear spring perches
    • Front suspension features lightweight race designed front knuckles
    • Adjustable camber shims and toe links
    • Lightweight wheel bearing assemblies
    • Aluminum upper and lower control arms with steel spherical bearings
    • Lightweight front suspension K-member with integrated engine mounts
    Wheels/Tires
    • WELD Racing lightweight forged-aluminum 17-by-4.5-inch front wheels, WELD Racing Double Beadlock, lightweight forged-aluminum 15-by-11-inch rear wheels
    • Mickey Thompson ET Front 27.5 X 4.0-17 front tires, Mickey Thompson ET Drag Pro Drag Radial 30.0 x 9.0 R15 rear tires
    Gears/Axles/Driveshaft
    • Mark Williams Enterprises modular 9-inch custom Drag Pak axle with a 4.30:1 final drive ratio
    • 9-inch aluminum center section
    • 40-spline superlight gun-drilled and pocketed axles
    • Micro polished and lightened ring and pinion for reduced rotating weight, delivering a 4.30:1 final drive ratio
    • Lightweight 4-inch diameter 7075 aluminum driveshaft, 0.125-inch wall thickness
    Brakes/Pedals
    • Mark Williams Enterprises quick change four-piston, aluminum brake calipers with machined lightweight billet pistons
    • Mark Williams Enterprises lightweight cross-drilled rotors and CNC machined aircraft alloy aluminum brake hats with slot-drive rotor attachment system
    • Lightweight racing overhung throttle pedal and mounting system
    • Tilton aluminum brake pedal, balance bar and master cylinders
    • Line lock and brake pressure switch
    Fuel System/Steering
    • ATL SFI-certified drag race fuel cell
    • Aeromotive brushless racing pump with dual inline filter
    • Flaming River 15:1 ratio manual steering rack
    Options/Packages
    • 18 exterior color options and three wrap/graphic options
    • Lightweight Engine Component Package includes Blackbird performance front cover and external oil pump kit
    • Rear anti-roll bar provides a softer rate bar, droplinks and arm kit
    • Available Data Package includes Holley V300SD logger, suspension travel sensors, O2 sensors, transmission temp, transmission pressure
    • Racetech Lightweight Carbon Seat Kit achieves an estimated 20 lbs. in weight savings
    • Driveline Lightweight Package includes a carbon driveshaft, transmission sump pan, aluminum rear axle yoke to achieve an estimated 7 lbs. weight savings
    Hustle Up and Reserve Your Order
    The 2026 Dodge Charger Hustle Stuff Drag Pak by Direct Connection is for track use only and will be available at a starting U.S. manufacturer’s suggested retail price (MSRP) of $234,995 (pricing excludes taxes and fees).
    The Charger Hustle Stuff Drag Pak will be race-prepared in Mooresville, North Carolina, by legendary race car builder Riley Technologies, which has a long history of collaborating with SRT on championship-winning race cars. The Charger Hustle Stuff Drag Pak will make its racing debut at the NHRA Gatornationals in Gainesville, Florida, scheduled for March 5-8, 2026.
    Customers can email [email protected] starting October 31 to be added to the wait-list to reserve a one of 50 Charger Hustle Stuff Drag Pak on a first-come, first-served basis. Full information on the Dodge Charger Hustle Stuff Drag Pak is available now at www.dodgegarage.com/drag-pak-experience/2026.
    The Charger Hustle Stuff Drag Pak will be on display at the Dodge NHRA Nevada Nationals Powered by Direct Connection on Oct. 31 – Nov. 2, and at the SEMA Show in Las Vegas on Nov. 4-7.
