Suspension
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by 392michael, Nov 9, 2025.
  1. 392michael
    392michael Member
    St. Petersburg
    Hello guys I have 2016 dodge challenger shaker 392 recently I have started hearing a rubbing / squeaky sound when making hard turns such as if I go in a parking lot and turn the wheel hard and just slowly drive In a tight circle it will have a constant groan sound and it will change tones and even vibrate at one point and I can’t pinpoint if it’s coming from front or rear any help ?
    Have you checked the level of your power steering fluid? If it is low, top it off and monitor for a leak. If that doesn't fix the problem, your power steering unit may need to be replaced.
  3. 392michael
    392michael Member
    St. Petersburg
    I think it’s electronic power steering
  5. 392michael
    392michael Member
    St. Petersburg
    Ok perfect where do I find the reservoir so I can check and monitor for any leaks I’ll do that first
  7. 392michael
    392michael Member
    St. Petersburg
    I’m gonna try to upload a video
  8. 392michael
    392michael Member
    St. Petersburg
