Beware of Fake Spark Plugs
Discussion in 'Dodge Challenger General Maintenance' started by SRT-Tom, Mar 26, 2026.
  1. fritzthecat
    Tom, from the looks of it, based on what our two cars came with, and on the RockAuto website, the Mopar ones ARE the NGK ones!
    HellKitten, have you changed the plugs in your car, and is it a 6.1? I’m guessing that buying from a Mopar dealer is the most expensive option.
  2. HellKitten
    No sir.. not yet , mine is a V6 so probably a bit of a PIA. But I have purchased OEM plugs off eBay for my V6 jeep a few years back, don't remember what I paid but the cost must of been reasonable.
    I am using "garage queen" as a figure of speech. I don't have a garage- just a high quality Covercraft car cover.
  4. fritzthecat
    UPDATE…
    On my last post, I had swapped the plugs between #8 and #4, figuring that the CEL code would move to P0304, indicating a misfire on cylinder 4. I reset the code and drove around. Now it’s running fine, with only a very minor shudder in the engine at times, and no error code. So, nice, but why?
    Here’s a question - how does the computer detect a misfire? And since these engines have 2 plugs per cylinder, do they both have to be faulty or will the computer detect a problem if only one is bad?
    The PCM computer detects a misfire by monitoring the crankshaft sensor signal. If a cylinder does not fire, it will slow the crankshaft rotation at the time it should be accelerating. This slight fluctuation can be filtered out by the PCM and identified as a misfire. The PCM uses the crankshaft position sensor to determine the timing of the spark plug firing and the fuel delivery. If the PCM miscalculates any of these parameters, it can cause a persistent misfire.
    I would think that the PCM would detect if either spark plug is bad in a cylinder. That is because both plugs are necessary for a more complete and efficient burn (i.e., increased horsepower and torque), smoother acceleration, quicker throttle response and a more complete burn (i.e., fewer unburned hydrocarbons and other pollutants).
  6. fritzthecat
    UPDATE…
    Ok, so finally after swapping the plugs between #8 and #4, the CEL code did change to P0304, indicating a misfire on cylinder 4. So, that's enough evidence to say that it's the spark plugs failing.
    At this point I figure it's worth changing them all I'm just wondering what's the best tradoff between the cheapest plugs and the most expensive.
    baccaruda likes this.
    As previously stated, buy Iridium NGK plugs or the MOPAR ones. They will last you up to 100K miles. Paying a little more, up front, is your wisest choice. You don't want to be changing 16 plugs after 30k miles.
  8. fritzthecat
    Hey, Tom, appreciate the advice, but here's the confusion...
    Spark plugs come in 3 types, Platinum, Double-Platinum, and Iridium. The Mopar ones (SPLZTR5A13) are by far the most expensive at $10.88 each. They are made by NGK. But they're not Iridium, not even Double-Platinum, they're just regular Platinum. And it calls out another NGK plug (3381 G-Power) as a replacement and those are only $5.45 each. Wonder what the difference is?
    NGK has a Double-Platinum one (4998 Laser Platinum), supposedly better, for $9.23 each. Ok...
    NGK has a Iridium one as well (2314 Iridium IX), supposedly top-of-the-line, for $6.40 each! Quite a bit less.
    But they also have a closeout special on AUTOLITE XP5263 Iridium XP ones, for $3.06 each. That's a great deal compared to the Mopar ones. Is there really that much difference? The Autolite should be better, they're Iridium!
    So a full set of Mopars = $174. Full set of the NGK Iridiums = $102. Autolite Iridiums = $49.
    What's a muther to do??? :Big Laugh:
    I would buy the NGK iridiums. They are a great plug and are specified for the SRT. Autolites are mid-tier plugs and sometimes have longevity issues. After you install 16 new plugs in a HEMI, you don't want to do it again after 60K miles. Read the following link:
    Are Autolite Spark Plugs Good? An Honest Look at What You're Actually Getting - Daily Car Tips
    Here are the advantages of an iridium plug:
    • It’s as much as eight times stronger than platinum, so iridium can have a sharper center electrode that conducts a more durable, powerful spark.
    • Iridium is much harder than even platinum, so it resists wear for up to 25% more lifespan.
    • Iridium has a melting point over 4,400 F which ensures it can handle the hottest ignition systems.
  10. Jack_r2
    Jack_r2 New Member
    Yesterday
    New York, United States
    I've seen so many guys get burned by fake plugs from random sellers on Amazon or eBay. The counterfeit ones use cheap metal and the gap is never right, they misfire right out of the box. That arc damage picture is crazy, it's scary how close they can look to the real thing. I stick with buying from Summit, Jegs, or the local dealer now. The money saved isn't worth the headache of chasing a misfire that ends up being caused by the plugs themselves. Have you ever actually gotten a set of fakes yourself or just seen the warnings?
