2013 Challenger brake upgrade ?
Discussion in 'Challenger R/T Engine & Performance Modifications' started by Sabes13, Apr 13, 2013.
  1. Sabes13
    Sabes13 New Member
    I have a 2013 Chaenger R/T and want do a performance upgrade on the brakes.
    I am having a difficult time finding a brake kit for this year and wondering if someone can tell me if the brakes differ from the 2012 R/T and possibly make a suggestion for which company, beside Brembo or Wilwood, to go with.
  2. Storm Rider
    All the SRT's have Brembo's from the factory. I would think that would be a good place to start.
  3. IN2Huskers
    IN2Huskers Member
    Omaha NE
    brembo's?
    the brakes are the same as the 12's I have a 13 and did some research so anything that fits a 12 with vented rotors will fit your 13. Now on to the Brembo's for that kind of money you would be better off trading your car in for the SRT $4000 per axle I think for $8000 and your R/T you could probably trade for a 2012 SRT, There are many rotor/pad options out there from $300 to $600 if you do upgrade post it here and let me know if it was worth the money, as I am to understand the 13 got a brake upgrade, probably in the master cylinder or anti lock system to give them a firmer feel. I do like the look of the drilled and grooved rotor. Best of luck on you journey to stopping better.
  4. skellin
    skellin Member
    4381 N. Dixie Hwy Deerfield Beach, FL 33064
    You can get Dodge Challenger big brakes from AutoAnything for a great low price.
  5. vferrizz
    vferrizz Member
    Check out stainless steel brake co : ssbrakes.com
    Still not cheap but not quite as pricey as the Brembos.
  6. Lashlarue
    Lashlarue Active Member
    Look into the Charger police package. Far less expensive than Brembo's and nearly as good.
  7. jjmcanally01
    jjmcanally01 Active Member
    Tennessee
    Hey I have a 13 Challenger RT and did a complete brake upgrade. I bought everything on amazon from a company called Detroit Axel. Came with drilled/slotted rotors and pads. They work great!
  8. 70-426_10-SRT
    But the "Brembo" gives you .25 sec off your 1/4 mile times :)
    B5blueRT likes this.
