Headlights not working but all other lights work
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by Christina, Jul 25, 2026.
  1. Christina
    Christina Member
    Palmetto fl
    Both headlights went at the same time. All other lights work. Fuses are good
    Plz help
  2. Christina
    Christina Member
    Palmetto fl
    Holagen lights
  3. Christina
    Christina Member
    Palmetto fl
    Need help
    You may need a new battery. It may not have enough charge in it to turn on your headlights. If it is more than 3 years' old, get it checked or replaced.
  5. Christina
    Christina Member
    Palmetto fl
    New battery. And had it Ckd at two different places. 14.2 volts and approx 945 cold crank on a 800 ...
    You may have a bad relay, a faulty headlight switch or blown bulbs. Watch this video:
  7. Christina
    Christina Member
    Palmetto fl
    Thank. All were tested. They went at the same time driving home at night. All other lights work. Its very weird. Halo,fog,running...interior
  8. SRT-Tom
    When you checked the fuses, did you also look at the second fuse box in the trunk? There are 40 amp fuses for halogen headlights in positions 06 and 07.
    If these are okay, I am out of ideas. You should then take your car to a trusted mechanic or a Dodge dealership.
    HellKitten likes this.
  9. Christina
    Christina Member
    Palmetto fl
    yes trunk
    Didn't see any fuses in the front under hood...ty!
  10. baccaruda
    Hi there. Have you checked the voltage of the plug to the bulb that plugs into? and, if so, what's the reading? "With the head light switch on," I think this will narrow it down pretty quickly.
