Elimination of Turbo Lag
Discussion in 'Dodge Challenger General Discussions' started by SRT-Tom, Aug 9, 2026.
    Stellantis’ resurrected SRT divisi its performance arm responsible for things with names like Hellcat- has already started to explore the next evolution of performance powertrains.
    It unveiled a proof-of-concept system it called eBoost Air- an electrically assisted turbocharging technology designed to eliminate turbo lag without dampening the high-end power of large turbochargers.
    Turbo lag has long been one of the problems of large turbochargers. While bigger turbos can generate more horsepower at higher engine speeds, they require substantial exhaust flow before reaching peak efficiency, leaving a delay in throttle response at lower rpm.
    Stellantis says eBoost Air targets that gap by placing an electrically powered compressor ahead of the turbochargers. When the driver stomps on the throttle pedal, electronically controlled valves route incoming air through the compressor, creating positive boost pressure almost instantly. As exhaust flow builds, the conventional turbochargers take over, and the system returns to its normal airflow path.
    The concept isn’t a new one. Automakers including Mercedes-AMG, Porsche, Audi, and Ferrari have all played around with electrically assisted turbocharging in recent years, especially as emissions regulations have increasingly favor smaller, turbocharged engines.
  2. SFCR
    SFCR Full Access Member
    North Carolina
    That could be promising, especially if Stellantis drops the V-8s or replaces the supercharger. That thing is heavy!!
  3. Cloverdale
    In my limited experience 'turbo lag' is only noticeable in my manual trans between shifts and not at all in my automatic BMW's w/out the assistance of the technology described in Tom's post.
    Reports have stated that there is a noticeable turbo lag in the 420 hp. Charger R/T Hurricane engine.
