0 to 60 times
Discussion in 'Challenger News, Articles and Media Reviews' started by Wilfredopr, Aug 28, 2013.
  1. Wilfredopr
    Wilfredopr Member
    I try the 0 to 60 feature today and did a 5.8. I wonder what is the best time for a bone stock RT ?
  2. Rod_R
    Rod_R Full Access Member
    Kyle, TX
    The best time I have on R\T so far is 5.95.
  3. Wilfredopr
    Wilfredopr Member
    My first time was 5.88, last week I installed a cat back and I ran 5.80 only try it once, The cold air intake will be my next step, I'll keep you posted.
  4. moparornocar
    moparornocar Member
    Bone stock I got it to 5.43:head3:
    It all depends on how much wheel spin you get. Also, you will have better times on cooler days. The best time that I got with my SRT was 5.3.
  6. oknahs
    oknahs Member
    Great run
    Great run. Get it under the 5 second mark is as follows. Install a cool can, add problend to oil, and tranny. Get a pair of slicks from a friend, lower tire pressure, have only 2 gallons of gas. Clean out the trunk and take out the mini spare jack anything that weight a ounce. Get a friend who weights 120 lbs or less to drive the car. I guarantee you will have the best run ever! Good luck.
  7. Model maker
    I haven't done that yet & I am waiting. I have the R/T Plus with auto transmission with autostick, which is the BEST way to make the run, full automatic OR use sport mode & auto stick ?
    Bert
  8. moparornocar
    moparornocar Member
    I would have to say full auto mode, there set up to shift at the optimal power band under WOT. Found that out in my Sebring, ( my Chally is a stick) I use the auto stick to set up for curves or to hold a gear in the mountain's.
  9. Model maker
    Thanks, she has some pep & power and is fun to drive.
