Need new Pads and Rotors
Discussion in 'Dodge Challenger General Maintenance' started by Lady Scat 2021, Sep 3, 2026 at 10:05 AM.
  1. Lady Scat 2021
    Lady Scat 2021 New Member
    Thursday
    Virginia
    I’m getting a lot of information from dealers that doesn’t sound right. I have a ‘21 Challenger Scat Pack that has the Dynamic package. The dealer tells me the only thing I can replace Brembo with is Brembo. I just don’t have that money right now but don’t want to put on Car quest premium brakes another dealer is saying to use. I’m looking at ordering the rotors and pads and having another place(they said they can) replace. What are your suggestions to replace the Brembo and will I need to get calipers too? I wasn’t told I needed calipers, just rotors and pads.
  2. HellKitten
    You will here all kinds of stories out there..
    There are different companies that make brake pads and rotors for your Challenger.
    In regards to Car quest pads & rotors they probably just rebrand them under their own name. They are probably a decent product.
    If you want to see different pads and rotors for your Challenger you can go to rock auto.com and enter your Challenger info, I am sure there will be all kinds from cheap to higher end .
    Though I would not buy anything unless you have a shop that would install them for you. As most shops frown on it.
    Hope this helps.
  3. Lady Scat 2021
    Thursday
    Virginia
    Thanks. Yes, one place I called said if I order them they will install. So now I’m doing the homework.
  4. Lady Scat 2021
    Thursday
    Virginia
    How do I know if I have 4 or 6 pistons?
  5. Cloverdale
    Unless your pads wore to metal (which would've been audible) or there's brake pedal pulsation (from a rotor that's become untrue) it's unlikely you require rotor replacement on a 21 model car.
  6. Lady Scat 2021
    Thursday
    Virginia
    I do have 107k on it unfortunately.
    Green with Envy likes this.
  7. HellKitten
    You will probably need to give your VIN # to a parts supplier Car quest , O Riley auto parts, ect.
    Or call a Dodge dealership parts department and ask them what you have for brakes , 4 or 6 piston .
    You will want your VIN # in hand when you do this.
    You may also get responses from other members on this forum who know more than me asking for your VIN #
    I would suspect more than likely you have 4 piston calipers front & back , but I am not sure
    You also can tell by looking at your calipers if you're mechanically inclined,
    By looking at the caliper through the rim as you would see the piston bumps on the outside of the calipers.
    Take pictures with your phone and post them on here and I think that would be a big help.
  8. Cloverdale
    Wow! Must be a lot of daily highway mileage?
