What if my Key Fob battery is dead?
Discussion in 'Dodge Challenger General Discussions' started by Janning, Mar 1, 2015.
  1. Janning
    Janning Full Access Member
    Hi,
    I have 2015 Challenger RT Scat Pack. This has the square Key Fob (no "nose" on it)
    My question is, if the battery in my Fob is dead, how do I start the car? My 2014 Rt had the other type Fob, you could pop off the start button and use is similar to an old style key, but, as I said...this Fob is totally square. I know how to remove the metal key part from the Fob, but, can this be used to start n run my car? I realize its all brand new now...but, when that day comes - dead Fob battery- what do I do?
    Thanks, James.
  3. Janning
    I should have added, If the Fob battery dies and I'm out in middle of nowhere, and do not have a spare battery.
    What type of battery is it anyway?
    Also, this just hit me. What it the fob battery died and I was not in the car, and the car is locked?
    thanks James
    It is a CR2032 (or equiv.).
  5. kjosker
    kjosker Member
    Lewes DR
    I've been thinking about your problem, and so far, every idea wouldn't work. I thought, just have an extra in the car, then realizing that it's not going to help if you're locked out. So then I thought having the wife or girlfriend (or both) keep one in their purse. But again, no help if they aren't with you.
    So my answer would be, change the battery before you need to. Say once a year. Maybe between Thanksgiving and Christmas, as it seems that's when they ship and stock a lot of fresh batteries. Or when you change the smoke detector batteries at home.
  6. Janning
    why won't any of these work? the manual says if battery is dead, used the key instead of your finger to start the car... why won't this work?
    ALSO, there is a key hole in the door, so the metal extract from the fob should work...! why would it not?
    if u out your spare key in the car, it won't ever lock. try leaving your keys on the seat, or even the trunk... nohing will lock... it knows you "left your keys in he car" and protects you.
    can you explain you line of thinking in detail,,?
  7. D'prived
    D'prived Active Member
    Key Fob
    I knew you could unlock the door with the key but I wondered about being able to start the car. Here's what I found in the owner's manual...
    The Keyless Ignition Node (KIN System) has four operating
    positions, three of which are labeled and will
    illuminate when in position. The three positions are: OFF,
    ACC, and ON/RUN. The fourth position is START.
    During start, ON/RUN will illuminate.
    NOTE: In case the ignition does not change with the
    push of a button, the RKE transmitter (Key Fob) may
    have a low or dead battery. In this situation, a back up
    method can be used to operate the ignition switch. Put
    the nose side (side opposite of the emergency key) of the
    Key Fob against the Engine START/STOP button and
    push to operate the ignition.
    Key Fob
    The Key Fob also contains the Remote Keyless Entry
    (RKE) transmitter and an emergency key, which stores in
    the rear of the Key Fob.
    The emergency key allows for entry into the vehicle
    should the battery in the vehicle or the Key Fob go dead.
    The emergency key is also for locking/unlocking the
    glove compartment. You can keep the emergency key
    with you when valet parking.
  8. hada71rt
    hada71rt Active Member
    Carol Stream, Il.
    Just pop out the button and put the square end of the fob in the hole.
    Even if the battery in the fob is dead this acts as a key and allows you to start the car.
    Many guys were never told about the button because it was packaged in the glove box when buying a new car and that's how they started and drove their cars until they found out.
    (OO [::::::::::::::::SRT:::] OO)
