2015 tail lights on older model
Discussion in 'Challenger Exterior Modifications Forum' started by Dakota21601, Sep 8, 2015.
  1. Dakota21601
    Dakota21601 Member
    Greenwood, IN
    Does anyone know if the 2015 tail lights are swappable on a pre 2015 car? Love the new taillight assembly and may end up with a 2011/12 at some point but would be sweet to be able to change these out.
  2. 10DYRT
    10DYRT Full Access Member
    Calgary, Alberta
    One of my friends here tried the conversion, unfortunately it is not feasible as you need to change the rear fascia as well, which makes it quite costly. The lights themselves fit okay it was a gap on the ends that was the issue. So he told me as I did not see it in person.
  3. Dan38
    Dan38 Member
    I have a 2014 with the 2015 rear tail piece. Only 1 issue, since they are LEDs which causes them to flash a little too fast. I have not attempted to correct this yet but suspect it will require adding some kind of resistor or wiring in a regular bulb somewhere in the circuit to bring the circuit load correct. If anyone else has been through this let me know.
  4. Dan38
    Dan38 Member
    I installed some 6ohm 50 watt resistors on the rear turn signal circuits, now they flash at normal speed for about 5 seconds and then reverts back to rapid flash. Hummph!
  5. UKCrafty
    UKCrafty Member
    Shame about them not working out!! I just went with the sequential tail lights for mine love em!
    Sent from my SM-N910T using Tapatalk
