My first time was 5.88, last week I installed a cat back and I ran 5.80 only try it once, The cold air intake will be my next step, I'll keep you posted.
It all depends on how much wheel spin you get. Also, you will have better times on cooler days. The best time that I got with my SRT was 5.3.
Great run Great run. Get it under the 5 second mark is as follows. Install a cool can, add problend to oil, and tranny. Get a pair of slicks from a friend, lower tire pressure, have only 2 gallons of gas. Clean out the trunk and take out the mini spare jack anything that weight a ounce. Get a friend who weights 120 lbs or less to drive the car. I guarantee you will have the best run ever! Good luck.
I haven't done that yet & I am waiting. I have the R/T Plus with auto transmission with autostick, which is the BEST way to make the run, full automatic OR use sport mode & auto stick ? Bert
I would have to say full auto mode, there set up to shift at the optimal power band under WOT. Found that out in my Sebring, ( my Chally is a stick) I use the auto stick to set up for curves or to hold a gear in the mountain's.
