2013 SXT Trunk Tail Lights
Discussion in 'Dodge Challenger General Maintenance' started by Byron Gray, Mar 22, 2018.
  1. Byron Gray
    Byron Gray New Member
    Belfair Washington
    Water got inside the lights that are on the trunk and it corroded a couple of the bulb connectors. I have had zero luck finding new connectors. I would rather not buy a whole new assembly or harness. Dose any one know what connectors they are and where to find them? Thanks.
    well for that year, all models had the same rear tail lights all they way up to 2014. 2015 was the year they remodeled the car as far as cosmetics....., best thing you can do is go to a wrecking yard and see what you can find there. you just cant buy new bulb sockets for these new cars yet.
    Byron Gray likes this.
  3. Byron Gray
    Belfair Washington
    Thank you I will keep an eye out. I have not seen any in the yards in the area where I live.
  4. IntimidatorRT
    may want to check with Rockauto.com to see if they have replacements for these. like I said, anything from 2009 to 2014 will work as they lights are all the same.
