2014 rt sub harness
Discussion in 'Dodge Challenger General Discussions' started by 14RT, Dec 17, 2016.
  1. 14RT
    14RT Member
    I wanted to put the factory kicker sub in my rt, I pulled the left trunk panel and couldnt find the plug and play harness connector. I thought all challengers had the plug and play connector, is that not true?
    If your Challenger had the base audio set up, you will have to add a harness.
  3. omariv11
    omariv11 Active Member
    I had the same issue u would have to get the harness set up I had cut my plug and play adapter and connected it to the amp
    Sent from my SM-G935T using Tapatalk
  4. 14RT
    14RT Member
    Ok thanks
  5. omariv11
    No problem bro
