2015 Challenger SP M6 Noise
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by daveinaz, Dec 27, 2016.
  1. daveinaz
    daveinaz New Member
    Does anyone else have a clunk when shifting from 4th to 5th gear?
    I don't feel it in any other gears. I can't not make it clunk even if I am cruising in 5th and push in the clutch while keeping RPM steady it clunks when I let out the clutch again.
    What do you all think?
  2. chithead
    chithead Full Access Member
    Landis, NC
    Odd. Mine clunks through almost every gear, and grinds going into reverse. Has done that since about a week after getting the car, just thought it was normal after reading about that thick gear glue/oil in the transmission from the factory.
