Adjustable Sway Bar Ends
Discussion in 'Challenger Wheels, Tires and Brakes Forum' started by RT_6Speed, May 27, 2013.
  1. RT_6Speed
    RT_6Speed Full Access Member
    Does suspension belong in the wheel/tire/brakes section ? :) Anyone running adjustable sway bar end links on an R/T-SRT and/or aftermarket end links? After lowering mine I've developed a pop when one side is loaded and the other side unloads. From reading it seems the factory end links don't quite fit like they should. If you have aftermarket sway bar end links would like to know what brand and how they fit.
  2. jonmandude
    jonmandude Full Access Member
    the dreaded rust belt
    I do not currently have aftermarket sways, but when I do get them I am going with Whiteline bars and BWoody links. The factory links are crap and once you upgrade the sways you will get issues (like your pop).
