Air Bag Light & Another Odd Question
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by cddroid, Jan 29, 2012.
  1. nc2011challenger
    nc2011challenger New Member
    I had the same issue with my air bag light being on,
    step one turn car off locate connectors under driver and passenger seat they are yellow each seat has one near the front and on near the rear so yes you will have to unplug the front the go in the back seat and unplug the rear connectors blow in each side, you can use a can of air but do not hold to close b/c you can end up spraying moisture in the connectors after a quick blow I used some connector grease (lightly) plug back in do one at a time and one seat at a time no sure if it matters that's just exactly what I did and problem was solve also make sure after you do this to make sure that you push red tab in to lock. pull out (toward you) to unlock each connector is fasten into place so the side of the connector that is facing you is indeed the side that you would pull to get off squeeze top end closest to you and pull being that the connector is fasten into place you should be able to do this with one hand it will not hurt any wires as long as you are only pulling on connector I hope this work like it did for me the darn dealership wanted to charge me 95.00 just to look at even with me telling them I have a connector problem and the code from the light being on so if your not under warranty 3600miles or 3year but there is a page when you log on to dodge.com an under owner tab you can post your issue to dodge if they get enough they will issue a recall also you can call have vin number ready b/c you will be on hold for a while 35min for me to talk to dodge 1800-423-6343:grd:
