Challenger Acronyms Used
Discussion in 'Site News' started by SRT-Tom, Jun 13, 2021.
    For you newbies, here is a list of the most common acronyms used on Challengerforum.com.
    A5 = 5 speed automatic
    A8 = 8 speed automatic
    ABS = Antilock Brake System
    AEV = Active Exhaust Valves
    AFR = Air Fuel Ratio
    AT = Automatic Transmission
    ATF = Automatic Transmission Fluid
    AWD = All Wheel Drive
    Axle Back = Exhaust system after the rear axle
    B5 = B5 Blue Color
    BCM = Body Control Module
    Blower = Supercharger (See also SC)
    BOV = Blow Off Valve
    Brembo 4 = 4 Piston Brembo Brakes
    Brembo 6 = 6 Piston Brembo Brakes
    CAI= Cold Air Intake
    Cats = Catalytic Converters
    Cat Back = Exhaust system after the Catalytic Converter
    Catted Mids = Midpipes with Catalytic Converters built in
    CDV = Clutch Delay Valve
    CEL = Check Engine Light
    COP = Coil On Plug
    DCG = Drivers Convenience Group Package
    DD = Daily Driver
    DI = Direct Injection/Direct Fuel Injection
    DR= Drag Radials
    DRLs = Daytime Running Lights
    DS = Drive Shaft
    DTC = Diagnostic Trouble Code
    ECT = Engine Coolant Temp
    EGR = Exhaust Gas Recirculation
    EGT = Exhaust Gas Temperature
    EHPS = Electro-Hydraulic Power Steering
    ESC = Electronic Stability Control
    EVIC = Electronic Vehicle Information Center
    F8 = F8 Green Color
    FCA = Fiat Chrysler Automobiles
    FI = Forced Induction or Fuel Injection
    FM = Friction Modifier
    Forged = Adding Forged internal engine parts to replace weaker cast parts. Most notably Forged Pistons
    FSM = Factory Service Manual
    FWD = Front-Wheel Drive
    Gen3 or GenIII = 3rd generation Hemi Engine
    Getrag = Limited Slip Differential
    HC= Hellcat
    HEMI = Hemispherical combustion chambers
    HID = High Intensity Discharge Headlights
    HF Cats = High Flow Catalytic Converters
    HLA = Hydraulic Lash Adjuster
    HU = Head Unit
    HUD = Heads-Up Display
    HVAC = Heating, Ventilation, and Air Conditioning
    IAT = Intake Air Temperature
    ICE = Internal Combustion Engine
    IFS = Independent Front Suspension
    iDFSO = Interactive Decel Fuel Shut-Off
    IRS = Independent Rear Suspension
    LA = 2015- Current Challenger Platform
    LC = 2008-2014 Challenger Platform
    LCA = Lower Control Arm
    LHD = Left Hand Drive
    LSA = Lobe Separation Angle (Camshaft)
    LSD = Limited Slip Differential
    LT = Long Tube Headers
    M6 = 6 speed manual
    MAP = Manifold Air Pressure (IE: MAP Sensor)
    MF = Microfiber (C'mon now, get your head out of the gutter! )
    Mids = Mid Mufflers or Mid Pipes
    MDS = Multi Displacement System
    MIL = Malfunction Indicator Light
    MOPAR= Combination of the words MOtor and PARts. Parts, service and customer care organization within Fiat Chrysler Automobiles
    MT = Manual Transmission
    MY = Model Year
    NA = Naturally Aspirated
    NAG/NAG1 = 5 speed automatic transmission (New Automatic Gearbox 1 [1st Generation])
    NOS = Nitrous Oxide or Nitrous Oxide System
    NVH = Noise, Vibration, and Harshness
    O2s = Oxygen Sensors
    OCI = Oil Change Interval
    PCM = Powertrain Control Module
    PCP = Plum Crazy Purple/Plum Crazy Pearl color
    PCV = Positive Crankcase Ventilation (IE: PCV Valve)
    PDC= Power Distribution Center
    PDI = Pre-Delivery Inspection
    PN = Part Number
    POC = Priced Order Confirmation
    PP = Performance Pages
    PPF = Paint Protection Film
    PSI = Pounds per Square Inch
    Raisin Bran Hood = New "Two Scoop" Hellcat hood
    Reps = Replica Wheels (IE: Hellcat Reps, Demon Reps)
    Res Delete = Resonator Delete
    RHD = Right Hand Drive
    RWD = Rear Wheel Drive
    RWHP = Rear Wheel Horsepower
    SA = Spark Advance
    SC = Supercharged, or Supercharger
    SG or SGII = Sound Group, Audio System
    Shaker = Shaker Hood Scoop
    SI/DO = Single In, Dual Out muffler design
    SI/SO = Single In, Single Out muffler design
    Six Pack = Three two-barrel carburetors
    SP = Scat Pack
    SPAG = Scat Pack Appearance Group
    SPS = Scat Pack Shaker
    SPWB = Scat Pack Wide Body
    Squirters = Nozzles that squirt oil under the piston to keep them cooler
    SRS = Supplemental Restraint System
    SRT = Street & Racing Technology (High Performance Group Of FCA)
    STP = Super Track Pak
    ST or Shorties or Shortys = Shorty Headers
    TCM = Transmission Control Module
    TIPM = Totally Integrated Power Module
    TB = Throttle Body
    TPMS = Tire Pressure Monitoring System
    TSB = Technical Service Bulletin
    TW = Treadwear
    UCA = Upper Control Arm
    UOA = Used Oil Analysis
    VIN = Vehicle Identification Number
    VON = Vehicle Order Number
    VVT = Variable Valve Timing
    WB = Wide Body
    WBSP = Wide Body Scat Pack
    WBSPS = Wide Body Scat Pack Shaker
    WIN Module = Wireless Ignition Node
    WOT = Wide Open Throttle
    ZF = Manufacturer of 8 Speed Automatic Transmission (2015+) (See also A8), and 2015+ Rear Differentials
    5.0 = Uconnect 5" Head Unit
    7.0= Uconnect 7" Head Unit
    8.4 = Uconnect 8.4" Head Unit
  2. B5blueRT
    Okay SRT-Tom, fess up. How many of these did you make up? LOL... nice list, thanks.
    NOS = also stands for New Old Stock referring to NEW, Un-Used Old Part found on the shelf
    and
    MOPAR= should NEVER be used in the same sentence with Fiat
  4. Wm TPA SXT
    Wm TPA SXT Full Access Member
    PW7 = Bright / Brite White
    The Worse thing I hate seeing is younger ages calling the Challengers - Chally? Houston we have a problem!!!
  5. NC20RT
    Especially in the petroliana collector's world and I imagine many other places. NEW OLD STOCK
  6. Maxedwell
    Maxedwell Member
    Missouri
    Very nice - I’ve owned a Challenger for 11 plus years and still learned something. Do your own research on this one? Kudos!
  7. mikeT
    mikeT Full Access Member
    AZ
    FWD? Challenger?
  8. Wm TPA SXT
  9. HorsepowerMuch
    HorsepowerMuch Member
    PTM = Pedal To the Metal
  10. HorsepowerMuch
