Cold Weather and CAI are a good match
Discussion in 'Dodge Challenger General Discussions' started by Hopslayer, Oct 15, 2021.
  1. Hopslayer
    It was in the mid forty’s on the way to work today. Sad that I will need to put my car in storage soon, but my supercharged SXT Plus and CAI are going to make the most of this cool weather while we can.
    gostro likes this.
  2. Farmer Fran
    Earth
    with DA at 150ft you should definitely get good times. What HP/TQ are you pushing?
    Cool weather definitely increases the Hemi's power. The only down side is that tires lose some of their grip on cold road surfaces.
  4. Hopslayer
    Dyno numbers.
  5. Hopslayer
    My tires seemed to grip ok, but in 4 days of cold weather I had one drop from 32 to 27lbs of pressure and the other 3 dropped a bit too.
    For every 10 F degrees of temperature drop, tires will decrease 1-2 psi.
  7. Wm TPA SXT
    Wm TPA SXT Full Access Member
    You can get just as much performance with a AEM High Flow Air filter then the expense of a CAI and dont have to Oil the Filter.
    Truthfully the factory Systems provide ample for the HP and on 15 and up go to the Hell Cat setup with Inlet Tube.
    Then go to a AEM Filter.
  8. stingray
    stingray Full Access Member
    California
    Does it really make a noticeable difference?:driver:
  9. mikeT
    mikeT Full Access Member
    AZ
    Yes Stingray you can notice the difference in the cold(see dense)air
    Quote,
    The temperature can fluctuate over 20 degrees throughout the day. Cooler temperatures generally mean higher air density while warmer temperatures mean lower air density. From just that change, engine fuel systems can need up to a 4% adjustment. Horsepower can drop more than 4% from that amount of temperature increase and get restored from that amount of temperature drop.
    stingray likes this.
  10. stingray
    California
    So if you have two identical Challengers with same engine one with the shaker option the other with the HC hood ( 2 extractors and one center intake) the shaker option will put that car in the lead in 0-60 or top end speed on a very cold day?
