EVIC Operation
Discussion in 'Challenger DIY/Tech Info' started by SRT-Tom, Jan 16, 2012.
Car Parts
    EVIC Description and Operation, RKE Customer Preferences
    The Electronic Vehicle Information Center (EVIC) uses both non-switched and ignition switched sources of battery current so that some of its features remain operational at any time, while others may only operate with the ignition switch in the “ON” position. When the ignition switch is turned to the “ON” position, the EVIC display will return to the last function being displayed before the ignition was turned to the “OFF” position.
    The EVIC system is comprised of several different components that communicate over the Controller Area Network (CAN) and Local Interface Network (LIN) Data Buses. If the system is inoperative a scan tool and the appropriate diagnostic information must be used to diagnose the system.
    The EVIC function buttons are used to operate the different functions of the EVIC system. Pressing and releasing the MENU button (1) allows the driver to select the Compass/Temperature, Trip Computer, Personal Settings or System Status functions. The STEP button (4) is used to toggle through options or features of the Trip Computer, Personal Settings or System Status functions. Pressing and releasing the RESET button (3) allows the selection of setting or resetting of the function currently displayed at that time. Pressing and releasing the C/T (compass/temperature) button (2) will cause the EVIC to return to the compass/temperature display mode from any other mode.
    EVIC DISPLAY MODES
    SYSTEM STATUS MODE
    System display mode displays warnings and user interaction messages on the EVIC display. The driver can scroll to view multiple messages by using the STEP button. System warnings will always over ride the current display as they become active.
    When the appropriate conditions exist, the EVIC displays the following messages:
    -Turn Signal On (with a continuous warning chime)
    -Left Front Turn Signal Lamp Out (with a single chime)
    -Left Rear Turn Signal Lamp Out (with a single chime)
    -Right Front Turn Signal Lamp Out (with a single chime)
    -Right Rear Turn Signal Lamp Out (with a single chime)
    -RKE Battery Low (with a single chime)
    -Personal Settings Not Available - Vehicle Not in Park (automatic transmissions) or vehicle in motion (manual transmissions)
    -Left/Right Front Door Ajar (one or more, with a single chime if speed is above 1 mph)
    -Left/Right Rear Door Ajar (one or more, with a single chime if speed is above 1 mph)
    -Door (S) Ajar (with a single chime if vehicle is in motion)
    -Liftgate Ajar (with a single chime)
    -Left Front Low Pressure (with a single chime)
    -Left Rear Low Pressure (with a single chime)
    -Right Front Low Pressure (with a single chime)
    -Right Rear Low Pressure (with a single chime)
    -Check TPM System (with a single chime)
    -Check Gascap
    PERSONAL SETTINGS MODE (CUSTOMER PROGRAMMABLE FEATURES)
    Allows the driver to set and recall features when the transmission is in Park by pressing and releasing the MENU button until Personal Settings is displayed in the EVIC. Pressing and releasing the STEP button will scroll through the following personal settings choices:
    -Lock Doors Automatically at 15 mph (24 km/h) When ON is selected, all doors will lock automatically when the vehicle reaches a speed of 15 mph (24 km/h). To make your selection, press and release the RESET button until “ON” or “OFF” appears.
    -Remote Key Unlock When DRIVER DOOR 1ST PRESS is selected, only the driver's door will unlock on the first press of the remote keyless entry unlock button. When Driver Door 1st Press is selected, you must press the remote keyless entry unlock button twice to unlock the passenger's doors. When ALL DOORS 1ST PRESS is selected, all of the doors will unlock on the first press of the remote keyless entry unlock button. To make your selection, press and release the RESET button until “Driver Door 1st Press” or “All Doors 1st Press” appears.
    -Sound Horn with Remote Key Lock When ON is selected, a short horn sound will occur when the remote keyless entry “Lock” button is pressed. This feature may be selected with or without the flash lights on lock/unlock feature. To make your selection, press and release the RESET button until “ON” or “OFF” appears.
    -Flash Lights with Remote Key Lock When ON is selected, the front and rear turn signals will flash when the doors are locked or unlocked with the remote keyless entry transmitter. This feature may be selected with or without the sound horn on lock feature selected. To make your selection, press and release the RESET button until “ON” or “OFF” appears.
    -Delay Turning Headlights Off When this feature is selected, the driver can choose to have the headlights remain on for 0, 30, 60, or 90 seconds when exiting the vehicle. To make your selection, press and release the RESET button until “0,” “30,” “60,” or “90” appears.
    -Turn Headlights On with Remote Key Unlock When this feature is selected, the headlights will activate and remain on for up to 90 seconds when the doors are unlocked with the remote keyless entry transmitter. To make your selection, press and release the RESET button until “OFF,” “30 sec.,” “60 sec.,” or “90 sec.” appears.
    -Delay Power Off to Accessories Until Exit When this feature is selected, the power window switches, radio, hands-free system (if equipped), DVD video system (if equipped), power sunroof (if equipped), and power outlets will remain active for up to 60 minutes after the ignition switch is turned off. Opening a vehicle door will cancel this feature. To make your selection, press and release the RESET button until “Off,” “45 sec.,” “5 min.,” or “10 min.” appears.
    -Confirmation of Voice Commands — If Equipped When ON is selected, all voice commands from the UConnect™ system are confirmed. To make your selection, press and release the RESET button until “ON” or “OFF” appears.
    -Display Units of Measure in The EVIC, odometer, and navigation system (if equipped) can be changed between English and Metric units of measure. To make your selection, press and release the RESET button until “US” or “METRIC” appears.
    COMPASS/TEMPERATURE
    Compass heading and outside temperature are displayed on the EVIC display screen. One of eight compass headings to indicate the direction the vehicle is facing (N, S, E, W, NE, NW, SE, SW) and one of 15 compass variance settings can be programmed. Outside temperature is displayed in °C (degrees Celsius) or °F (degrees Fahrenheit). The audio mode is always present when the compass/temperature function is displayed.
    TRIP COMPUTER
    Press and release the MENU button until one of the following Trip Functions displays in the EVIC:
    -Average Fuel Economy
    -Distance To Empty
    -Elapsed Time
    --Display Units of Measure in
    Press the STEP button to cycle through all the Trip Computer functions.
    The Trip Functions mode displays the following information:
    -Average Fuel Economy Shows the average fuel economy since the last reset. When the fuel economy is reset, the display will read “RESET” or show dashes for two seconds. Then, the history information will be erased, and the averaging will continue from the last fuel average reading before the reset.
    -Distance To Empty (DTE) Shows the estimated distance that can be traveled with the fuel remaining in the tank. This estimated distance is determined by a weighted average of the instantaneous and average fuel economy, according to the current fuel tank level. DTE cannot be reset through the RESET button. When the DTE value is less than 30 miles (48 km) estimated driving distance, the DTE display will change to a text display of "LOW FUEL." This display will continue until the vehicle runs out of fuel. Adding a significant amount of fuel to the vehicle will turn off the "LOW FUEL" text and a new DTE value will display.
    -Elapsed Time Shows the total elapsed time of travel since the last reset when the ignition switch is in the ACC position. Elapsed time will increment when the ignition switch is in the ON or START position.
    -Display Units of Measure in: To make your selection, press and release the RESET button until “US” or “METRIC” appears.
    To Reset The Display Reset will only occur while a resettable function is being displayed. Press and release the RESET button once to clear the resettable function being displayed. To reset all resettable functions, press and release the RESET button a second time within 3 seconds of resetting the currently displayed function (>Reset ALL will display during this 3 second window).
    RKE TRANSMITTER CUSTOMER PREFERENCES
    AUTOMATIC (ROLLING) LOCKS
    The rolling locks feature can be toggled ON/OFF by using the scan tool only.
    HORN CHIRP DISABLING / ENABLING
    The horn chirp can be toggled using the scan tool or by using the Remote Keyless Entry (RKE) transmitter.
    To DISABLE (cancel) the horn chirp feature, press and hold the transmitter LOCK button for four to ten seconds. While pressing the LOCK button in, press the UNLOCK button. Release both buttons.
    To ENABLE the horn chirp feature, repeat the above procedure.
    OPTICAL CHIRP (FLASH) DISABLING / ENABLING
    The optical chirp can be toggled using the scan tool or by using the Remote Keyless Entry (RKE) transmitter.
    UNLOCK SEQUENCE
    The unlock sequence can be toggled using the scan tool or by using the Remote Keyless Entry (RKE) transmitter.
    Press and hold the transmitter UNLOCK button for four to ten seconds. While pressing the UNLOCK button in, press the LOCK button. Release both buttons.
    This will toggle between Driver door first and Unlock all doors function.
    Hidden EVIC Screens:
    How to Access and Exit
    To access the "easter egg" EVIC screens, do the following:
    Press and hold the Music Note (♪) key and the Compass key for a few seconds.
    Up and Down arrow moves through the screens.
    To Exit, just hit the compass key or the page key.
  2. genotex
    genotex Full Access Member
    WIzzzzzconsin
    thanks for the reprint... keeps it 'to the top' :) There is so much that is 'owner-controlled' if you just know how to access the information on these cars!
    For example, our state (and maybe yours!) recently passed a law that requires headlights to be 'on' whenever it's raining... and we have the ability to turn headlights 'on' whenever the wipers are going... voila! :) Nice ain't it!
    Thanks again ... worth searching the list once in a while to see what we are missing.
    :handshake:
  3. heminit
    heminit Full Access Member
    Central Arkansas
    Thanx for posting, great info.
  4. Storm Rider
    Tom is always coming up with great info for all of us. Thanks for sharing.
  5. challengerone
    challengerone Active Member
    Being a rather new member I just read this thread on our Evic system Thank you for caring enough to pass this kind of info on to our Forum.
    Rena
