One of the easiest ways to get more power from your engine is to dump the OE air filter and air intake system and replace them with high-flow aftermarket parts. Aftermarket air intake systems increase airflow to your engine. This is desirable because increased airflow allows your engine to burn more fuel, and more fuel equals more power. We would like to tell you about the option for your Dodge Challenger 2014 from AIRAID. The MXP Series air intake system positions a large 360º AIRAID air filter with a huge air inlet in the stock location, but encloses it in a roto-molded polyethylene airbox that seals against the hood, forming an enclosure. The MXP Series takes the Cold Air Dam Intake System to the next level. The molded polyethylene MXP airbox seals against the hood and forms a complete enclosure for the SynthaFlow or SynthaMax air filter. The airbox air inlets are located to allow only the coolest outside air into the airbox. This results in massive quantities of only the coolest air reaching your engine. Each filter is over 99% efficient, meaning it allows more airflow while filtering out dirt particles ordinary filters let pass. You get better performance without sacrificing air filtration. The MXP Series Cold Air Dam Intake System comes complete with everything necessary for installation, including comprehensive instructions. And it's backed by AIRAID's "No Hassle" warranty. Follow this link for more AIRAID Products https://www.carid.com/airaid/ What do you think about it?
