Fog Lights stopped working
Discussion in 'Challenger Mechanical Problems Forum | TSB's' started by Detroitdigital, Mar 18, 2018.
  1. Detroitdigital
    Detroitdigital New Member
    Detroit
    I have a 2010 dodge challenger with standard fog lights. The fog lights stopped working one day this week.
    I checked the push button and the headlights only still work.
    The fog light icon on the cluster still comes on when I push the fog light button.
    My brights (hibeams)are not on.
    I replaced the light bulbs thinking they were bad. Still did not work.
    I looked in both the front and rear fuse boxes. There are no fuses or relays marked for fog lights and nothing was blown.
    The car manual and online diagrams do not show a fuse location for fog lights on the 2010 year model challenger.
    I spent hours researching on google, youtube and challenger forums. Nothing!
    My fog lights still do not work. Does anyone have any recommendations?
  2. Shaker G
    Shaker G New Member
    Pa
    I have the same problem with my 2016 challenger R/T shaker let me no if you find out what is wrong and I will do the same.
  3. ransomlowery
    ransomlowery Active Member
    Rochester, MN
    Do you use the auto or do you manually turn on and off the lights? Try manually turning the lights on then turning on the fog lights. Also check the drl setting and try turning that on or off..
    You know those damn things are PROGRAMMED by the dealer?
    My son had an FBI Charger he added the fog lights and the switch, and to make them work you have to have the dealer program them.
    F'ing computers (/Rant off)
  5. IntimidatorRT
    yep, what he said ^^^^^
