How do You Launch?
Discussion in 'Track Talk' started by SRT-Tom, Dec 16, 2012.
    For those of you guys who have taken your Challengers to the track, how do you launch?
    Do you have ESP fully disabled, partially disabled, or on. I would guess you need to keep ESP fully engaged unless you have slicks and can do a burnout.
    Also, at what rpm do you launch?
  2. Black Voodoo
    Black Voodoo Member
    I have the Predator, so I put it in dyno mode and change tire size for my drag setup. I do a moderate burnout, then roll through the burnout in second gear and let off. When you hear the chirp as tractlon is restored, tires are ready. Since my torque converter is stock, I don't try to stall however I wait until the last yellow to launch. I have my shift points raised to 6400 and I let the car auto shift, going through the traps around 6200 in 3rd.
    What was your best time with this technique?
    It was cold today and Hemis like freezing temperatures, so I decided to do a 0-60 mph run. Well, my RSA tires were cold and they went up in smoke. I only managed a 5.8 sec. run with traction control on. Smoking tires look impressive, but you aren't going anywhere!
  5. Black Voodoo
    Black Voodoo Member
    Personal best 12.497 @ 109.83 and a 1.801 60'.
  6. 10DYRT
    10DYRT Full Access Member
    Calgary, Alberta
    With my street tires dropped to 26psi. ESP partially off (R/T) moderate burnout to warm up the rubber, launch at about 700 rpm in auto stick, shift point set at 6200 and firmness
    increased ( Trinity 91 canned tune).
    Best was a 1.992, 60ft with a 13.345 @ 103.8 mph. Elevation at the track is about
    2600ft.
    Can hardly wait till next trip to Seattle to see what it will do in good air.
  7. Black Voodoo
    Black Voodoo Member
    ^^^^ A set of drag radials and you're in the 12's no problem!
  8. Lashlarue
    Lashlarue Active Member
    Shallow stage, brake torque at 1000rpm, leave on the third yellow.Roll into the throttle. Took me about 30 passes to get my 60 ft from 2.4 to 2.00.Stock RSA's.I don't spin so whether esp is on or off doesn't seem to effect my times.Works great at the track, on prepped blacktop, not so good on concrete.
