So we all love the Hemi Engine but it could be improved. Engine Remanufacturers typically address the following issues when remanufacturing a 5.7 Hemi: COMMON ISSUE: SOLUTION: Dropped valve seats •Oversized valve seats installed with more press fit Scuffed pistons or worn piston rings •Upgraded piston ring pack including steel compression rings for greater durability •Updated aftermarket piston with additional oil drainbacks for better oil return Premature bearing failure or engine knocking •Blocks and cranks are completely manufactured to exact tolerances utilizing CNC machining equipment •Crankshafts are micro-polished to extend bearing life. Head gasket failures or leaking head gaskets •Multi-Layer Steel (MLS) head gaskets are used which resist heat and avoid head gasket failures. •Compression height on the pistons is reduced to maintain factory compression ratio specifications. •Both the block and cylinder heads are precision machined to exact specifications. OTHER UPGRADES/BENEFITS that SHOULD be done from the factory: •Graphite coated hypereutectic pistons resist scuffing and damage to heat much better than factory aluminum pistons •Moly piston rings reduce friction and cylinder wall wear to extend the life of the engine •Viton rear main seals protect against heat and leaks •Connecting rods are honed (both the little and big ends) to ensure uniformity •Chrome plated valve stems resist scuffing and heat for greater durability •Every Hemi engine is 100% simulation tested very thoroughly by skilled technicians. Why doesn't Mopar concentrate on improving and building the engines right the first time instead of putting a stupid hood scoop on your car or changing the appearance? Why don't you follow the european manufacturers and refine the drive train instead of concentrating on the looks of the cars. The Challenger is perfect in appearance as it is right now. Leave it alone in my opinion and build the engine right!!!
really the only problem I have had with my 2009 is the timing chain recall and a an alternator. 97,000 miles so far
Any I understand that but why not produce a rock solid engine and give the consumer a great product??? Take some pride in what you produce!!!
