Lowering
Discussion in 'Challenger Wheels, Tires and Brakes Forum' started by Hopslayer, Nov 6, 2019.
  1. Hopslayer
    Detroit Lakes, Minnesota
    Who has used springs to lower their Challenger? What were the benefits/drawbacks and would you recommend it? Thanks
    I have a 2009 RT. I was able to get springs and shocks from another 2009 SRT. It lowered my car about 2 inches which gives my car a stance that is acceptable to the types of roads we have here in Louisiana. I don’t like it slammed to the ground. The handling improved greatly as I love to drive autocrosses we have around here every once in a while. BTW SRT’s came with the Bilstein shocks and springs.
  3. Jelli79
    Jelli79 Member
    canada
    So in general terms lowering the car with springs will normally give you a stiffer ride and combined with the lower center of gravity will improve handling, the cons are of course a harsher ride and less ground clearance
  4. IntimidatorRT
    My ride is just a little rougher than normal. But I can take that swap for the handling. Plus the lower stance.
  5. Hopslayer
    What tires are you running? I’d love to go 2 inches lower, but would worry about rubbing as I have 315/35/20s in the rear. Apparently I should also replace the struts/shocks at the same time, so someone told me to look at coil over kits. They range from $600-$4000.
  6. IntimidatorRT
    I am running Firestone 245/45/20. My next set will be 275/40/20
  7. 10DYRT
    10DYRT Full Access Member
    Calgary, Alberta
    I also am running SRT struts and springs ( Bilstien) mine dropped about 1 1/2 inches.
    Runnning 245's on the front and 305/35's on the rear.
    Hopslayer and IntimidatorRT like this.
