My 1972 Rallye build thread!
Discussion in 'First Generation Challenger Forum' started by Manbearpig, Jan 29, 2015.
  1. Manbearpig
    Manbearpig Member
    This will probably be a slow thread as my car is a really good driver at the moment as it is. Its just ugly lol
    I bought this car around August of 2013 pretty much in the current condition its in.
    Since then:
    Tranny fully rebuilt with a new turbo action converter
    Rear end rebuild
    I yanked the old rusty shorty headers out and ceramic coated them
    Originally a white/white 318/727 car it now has a big block B383
    Well I can't get my videos to embed soo...
    Idle
    http://www.youtube.com/watch?v=DjfeRLHkN2Q
    Cold start
    http://www.youtube.com/watch?v=lK1fQyPzoTQ
    A little burnout
    http://www.youtube.com/watch?v=aLqO1VvD3yw
    Just playing with the GoPro..
    http://www.youtube.com/watch?v=LTiSz2DEBTs
    Sometime this year I plan on starting the body work. When I bought the car I received every body panel I need with it; quarters, trunk floor, wheel wells, filler panel between trunk and rear window
    Also planning on building a fuel injection system for the 383 sometime soon too. Unless I come across a 440 shortblock before then
  2. Shaggy
    Hey MBP, is this the same one for GMFS? If not, welcome anyways.
    Love the challenger you got. Is the body really bad enough to replace the panels? Look forward on watching this build on here!
    Just watched some of the videos, man that beast sounds mean!
  3. Manbearpig
    Manbearpig Member
    Yep! Same MBP from GMFS/AoT/GMSB
  4. Shaggy
    I see you posted this on GMFS. Keep this post updated here too would ya.
  5. Manbearpig
    Manbearpig Member
    Definitely will :thumbsup:
  6. Manbearpig
    Manbearpig Member
    To do list
    NEED:
    • Fix collector gaskets
    • Upgrade factory wiring to remove high load off of bulkhead connector and indash ammeter
    • Install WBO2
    • Figure out why third gear is a bitch (valve body)
    • Retune the asshole Edelbrock carb
    • Work with or trash distributor/mopar digital ignition in favor for something actually decent.
    • Ditch the Flowmasters
    • Need steering pump
    • Fast ratio box(?)
    • Better brakes, lines, rear disc
    • Fix shotty weld job on floor pans
    • Find shop to replace quarters, trunk floor, trunk filler panel, maybe rockers?
    • Actual matching paint job
    • Fixed cracked dash
    WANT:
    • Purchase Jeep TJ CPS sensor
    • Machine/Weld intake for injector bungs
    • MS3X with 36-1 crank wheel
    • Aeromotive Stealth pump
    • Trash the 727 for a 6speed (rework tranny tunnel)
    • Fiberglass hood
    • B-Body 8-3/4" or D60 rear
    • Wider rear wheels
    • Rear 4link
    • LS MOTOR (bye bye resale)
    • G3 Hemi motor (Way too expensive for my blood in the salvage market)
    • Continue doing massive burnouts everywhere
    • Better looking seats
    • Better looking headliner
  7. Shaggy
    What are you going to put on after you ditch the flow masters?
  8. Manbearpig
    Manbearpig Member
    Really wanting to fit an Xpipe in there somewhere with some Borla XR1s
  9. Shaggy
    Do the make kits/systems to fit your year?
  10. Manbearpig
    Manbearpig Member
    TTI has a system and would look a whole lot better under there compared to the slapped together shit it has now
