I have recently added a Diablo T2 tuner to my 2010 Challenger RT. I instantly started getting code faults related to the catalyst system. I tried both the canned 91 & 93 tune. I contacted Jay Greene to see what he thought. He confirmed what I was thinking that due to the mods on my car adjustments to the tune may be needed. I decided to get a Greene tune which I had been thinking about for a while. I loaded the tune and went for a drive with no codes. After taking a couple of drives with no issue I assumed all was ok until yesterday. We went out in the morning which was very cool air temp, 7 deg Celsius, and not more then 2 minutes into the drive I had a fault come up. The code is P2096 which I have researched to find is related to exhaust bank 1 -O2 sensor before the cat. Has anyone else had these issues? I am going to check wiring and look for exhaust leaks when I have time. Engine Mods BBK long tube headers BBK 85mm throttle body KnN CAI Edelbrock Victor II intake and fuel rails Blastin Bob’s resonator delete
You didn’t list what engine mods you have but I have a 2009 RT with headers , exhaust and 6.1 intake manifold. I have the trinity tuner also and run the 91 tune and have no issues or codes. Sent from my iPhone using Tapatalk
About 100 miles after my 1st Diablo tune on my 2010 Challenger SRT I started getting code faults PCM0430=Cat System Efficiency below Threshold & PCM2098=Post Cat Fuel Trim System Lean. I tried 3 different tunes and it went away for awhile, then P0430 came back and stayed. After about a month (probably closer to two months) I finally took it in to the dealer. They cleared the code and told me to go drive it. WTF, I already told them I did that. 18 miles and the code came back. I took it back in and they replaced all 4- O2 Sensors. 100 miles later, same code, and I have not been back because the only other Chrysler Shop is another 75 miles farther. Gas Mileage never changed, so I just live with the Engine Light and check code once a month. I had not done ANY MOD's but the tune when this all started
I cleared all the codes and took it for another run with a new 1/2 tank top up. Didn’t get any codes this time. We’ll see how it goes.
