R1concepts "Eline" Series Cross Drilled & Slotted Rotors
Discussion in 'Synthetic Motorsports' started by clkelley, Apr 4, 2012.
  1. clkelley
    clkelley Full Access Member
    R1Concepts Eline Series Cross Drilled & Slotted Rotors
    RECEIVE An Added 10% OFF With PROMO CODE= CK10
    R1 Concepts ELINE SERIES BRAKE DISC WITH SILVER ZINC --
    When price is important and quality is essential. R1 Concepts ELINE Brake Rotors offer many of the benefits of an OEM part at a fraction of the cost.
    • Cross-Drilled and Slotted Design
    • Drilled holes provide maximum air circulation for increased cooling
    • Holes are countersunk which reduces heat build up
    • Exclusive R1 Concepts Diamond Slot increase brake pads bite
    • Diamond Tip use as indicator for brake rotor wear
    • Military Spec Plating for rust protection
    • Direct Fit OEM Replacement Brake Rotor
    • Double disc ground finish reduces rotor vibration
    • Meet Or Exceed OEM Standards For Excellence
    • Mill balanced brake rotors ensures long lasting durability
    • Brake rotors are casted using G3000 graded iron.
    R1Concepts Secure Online Catalog
    CONTACT ME For Questions, Concerns & Complaints
