steering wheel squeek
Discussion in 'New Member Check-In' started by cdurham38, Jan 31, 2017.
  1. cdurham38
    cdurham38 New Member
    I have a 2012 challenger and the steering wheel squeeks when I turn it.. I was looking for a power steering reservoir but don't see one.. What could this problem be
    You can first try checking the fluid level. The power steering reservoir is partially hidden. It is located under a flap near the base of the windshield (driver's side).
    Other causes of the squeak could be a dry steering column boot (rubber housing at bottom of steering column) or, less likely, upper control arms and tie rod ends.
