Tear Down of Pentastar Engine
Discussion in 'Challenger SE Engine and Performance Modifications' started by SRT-Tom, May 6, 2021.
    This Pentastar 3.6 liter engine ran an incredible 626,000 miles before giving out. It's amazing to see how well the engine held up. (Note- The oil was changed every 8,000 miles).
    Moparisto and Hopslayer like this.
  2. Wm TPA SXT
    Wm TPA SXT Full Access Member
    With well over half a million miles on it most all engines would be due for complete overhaul or replacement especially newer engines, id say its a good engine.
    Was told by my head mechanic at my dealer that the pentastar is the most dependable motor they make, it is made to go for a lot of miles.
    Here is a good video showing how a 3.6 is made.
    Moparisto and Jim Boucher like this.
  5. Moparisto
    The thumbnail of that engine on the video is the best view of the strange exhaust port layout I have yet seen.
    That Exhaust port layout just BEGS for a turbocharger. A turbocharger cares little if it is mounted on an old-school cast iron exhaust manifold or a long-tube header, from a performance standpoint. Cylinders just scavenge better and display more consistency on a long-tube header, with lower EGT's, but if you throw enough fuel at it, you get the same performance from a turbo right on a manifold.
    The 1000°C EGT's might not be the aluminum internal dividers' favorite thing, however.
    It looks like a modern engine, in general, I am just prejudiced against those exhaust ports, mainly for thermal reasons and consistency reasons.
    The block casting looks shrink-wrapped around necessary internal spaces for coolant and oil, as well as bolt bosses, for modern minimal weight.
    How much does that engine weigh? Half a Hemi?
