Torque for Stabilizer bar bolts
Discussion in 'Dodge Challenger General Discussions' started by Janning, Nov 22, 2020.
  1. 2017 Redline HC
  2. Janning
    Janning Full Access Member
    HA the bible has "lots of info"....this is the biggest most comprehensive documentation I've ever seen! thanks.! I hate the way the never stick to one name. It looks like that screen shot above is the one. They are calling where the bushing is a cradle. So 110-111 on the links and the "cradle" is 136 ft/lbs.
    What they calling "Fastener" they make it clear not to reuse it....but I have no idea what it is.
    Here's what happened, I went over like a block of cement...on drivers side...I didn't see it. I heard metal hit, wasn't that bad. It shifted over the entire stabilizer bar (sway bar strut? #1 in orig pic), one inch. Not sure how this happened I rolled over it came straight down. Nothign is bent I could prolly loosen and move back but while there I'm changing the bushings and end links. s_IMG_0085.jpg IMG_0082.jpg
  3. Janning
    Looking closer at this 136 ft pounds is pretty tight for that tiny bolt? and I don't see anything that could be a "fastener"
  4. 2017 Redline HC
    I still think that’s the stabilizer to crossmember support.
  5. Katshot
    Very simple:
    Stabilizer bar to crossmember: these are the main bushing clamp bolts. Torque them to 48 Ft.Lbs.
    Stabilizer bar heat shield to crossmember: these are the tiny little bolts for the heat shields. Torque them to 44 In.Lbs.
    Stabilizer link to stabilizer bar nut: this is the end of the link that connects to the stabilizer bar. Torque this to 100 Ft.Lbs.
    Stabilizer link to strut nut: this is the nut on the other end of the link. Torque this to 111 Ft.Lbs.
  6. Janning
    Thank You
  7. Katshot
  8. 70-426_10-SRT
    Make sure you read Inch lbs, not Foot lbs on these :)
  9. Janning
    NO DOUBT....I thought 44 ft was a bit high for the heat shield.....glad you said that
  10. 70-426_10-SRT
    I hate it when they MIX those in the same doc.
    44 In lbs = 3.666 Ft lbs :)
