Vehicle lifting systems - quickjack
Discussion in 'Dodge Challenger General Maintenance' started by TRCM, Dec 28, 2019.
  1. TRCM
    TRCM Full Access Member
    Southeast VA
    Has anyone used the Ranger BL-7000SLX QuickJack car lifting system (7000 lb) for lifting their car ?
    I am looking at this as it could be used on my Challenger, Ram, and Cherokees, both inside & outside the garage.
    I know I saw in a search (see below link) that 2010RT mentioned one I think, but not which one.
    https://www.challengerforum.com/threads/manual-trans-and-diff-fluid-change.4134/#post-18829
    I am concerned about the lifting points, as the jacking point pic below I found doesn't jive with using a straight lift track.
  2. 2010RT
    2010RT Full Access Member
  3. TRCM
    Southeast VA
    Why do you say it's a pain to get under the car....is it due to the length of the plates between the tires (you do have the longest one BTW) ?
  4. 2010RT
    Just takes a bit of adjusting to get it in place, nothing serious. I realize its the longest, as mentioned I have a 1 Ton I’m restoring that has a 9’ box on it. I figured the extra length for added stability.
  5. TRCM
    Southeast VA
    Well, ya convinced me.....just ordered a BL-6000XLT, along with the truck adapter set & wall hangers.......all was on sale too.
    I also verified all systems use the same pump & hoses, so if I get tired of using it sideways on my Cherokee (rails fit the Ram & SRT fine, but are too long for the Cherokee), I can order the shorter rails for the BL-5000SLX, and use the same pump and effectively have 2 systems....actually works out to be about 40% cheaper that way.
  6. IntimidatorRT
    found out that Home Depot also sells these too.
  7. TRCM
    Southeast VA
    And they have them on sale for less than quickjack does, and a better extended warranty......problem is the only one that will fit the pinch weld jacking points on a challenger is the 6000, and Home Depot doesn't sell that one
  8. IntimidatorRT
    get the pinchweld rubber adapters for a regular jack, that should work.
  9. TRCM
    Southeast VA
    I got adapters...but they aren't the rubber ones.
    The problem is how far apart they are...required the longest frame.
